Monty Versus Monty Sport whats the main differences #995453 04/29/10 05:52 AM
toyhooter Offline OP
OK. I was reading the tech ref's and I did not see a post describing the main differences between a "Monty" and a "Monty Sport". I have heard that there are substantial differences. Like the Sport does not have a user selectable transfer case. Is that true? What are the differnces?
ToyHooter
90 LWB Montero
Sliders, Dual Bouncies, K&N, Flowmaster, Rancho Stabalizer, KYB Gas Adjusts,
ARB Compressor Under Hood, ARB Locker Waiting Garage Floor, Spare Tire Bike/CB Ant Mount
"I didn't do it, you didn't see me, you can't prove it."
Bart Simpson
Re: Monty Versus Monty Sport whats the main differences [Re: toyhooter] #995454 04/29/10 06:57 AM
LandRaider Offline
They are totally different vehicles. Frames, bodys.... etc.
Re: Monty Versus Monty Sport whats the main differences [Re: LandRaider] #995455 04/29/10 01:57 PM
Maybe a better question is what do they have in common? Manufacturer, engine- sometimes, wheels- sometimes... Hmm, did I forget anything?
Re: Monty Versus Monty Sport whats the main differences [Re: toyhooter] #995456 04/29/10 02:43 PM
Depends on the year/generation. In the gen I body style (pre '92), the sport was a 2 door version of the Montero. 92 and on the 2 door 'sport' was no longer available in the US (although still available overseas).
In 97 Mitsubishi released the new 4 door Montero Sport which shares much of the Montero's running gear/drivetrain but because it is a completely different vehicle there were also many things not shared.
So that said, which Montero Sport are you asking about? <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: Monty Versus Monty Sport whats the main differences [Re: off-roader] #995457 04/29/10 04:06 PM
The differences I found between Gen 2s, 2.5s to Sports are.....
Bad things about Sports IMO.
Cheaper interiors.
stamped trailing arms.
No super-select (2wd, awd, 4Hlc,4Llc)
spare tire located behind rear end. (easy to tear on rocks)
drives more like a car.
Good things.......
Same motors and trannys as Montero standard.
looks sportier
rear lift gate opens vertically.
still absolutely capable.
I was told the sports are based from the Titan pick up truck. From what I can tell the standard Montero is built much tougher than the Sports. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Monty Versus Monty Sport whats the main differences [Re: cmonty72] #995458 04/29/10 04:21 PM
LandRaider Offline
Sports are based off the Gen 1 leaf sprung chassis, and monteros are based off the coil spring chassis.
Stradas and montero sports share the same chassis.
Re: Monty Versus Monty Sport whats the main differences [Re: LandRaider] #995459 04/29/10 07:24 PM
Later Sports have rear coils......with stamped trailing arms.
A three link just like Gen IIs but lighter duty trailing arms like this. 2001 Sport rear end stolen pic from Pirate.
Re: Monty Versus Monty Sport whats the main differences [Re: cmonty72] #995460 04/29/10 08:22 PM
Sport was based on pickup truck frame/suspension/driveline, with engines ranging from the 2.4 to the 3.5. Leaf spring rear up to 99, then coil spring rear afterwards. Many 2wd models. Quite capable when fully equiped. Air locker available, but somewhat rare, esp. in the leaf spring models, and that diff will bolt into a leaf gen1, but is about 2" wider, and has rear disk brakes.
Re: Monty Versus Monty Sport whats the main differences [Re: off-roader] #995461 04/30/10 12:48 AM
I really didn't know what model to ask about. I had no idea how long they had been produced, so it was just a general question. You guys have really covered the bases though. Lots of good info. I'm always thinking/looking for that genius junk yard bolt on to make the perfect hybrid Mitszoid one off truck. Key words "bolt on".
ToyHooter
90 LWB Montero
Bart Simpson
Re: Monty Versus Monty Sport whats the main differences [Re: toyhooter] #995462 04/30/10 01:41 AM
I meant Triton not Titan...... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Did we cover enough ground? <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6346 MB (Peak: 0.7428 MB) Data Comp: Off Server Time: 2026-06-07 05:43:01 UTC
