what can be bolted to a 92 montero trans? #995583 04/30/10 02:20 AM
shawnsdad Offline OP
I have a dodge dakota with a 3.9. would that bolt up? does anyone make a switch over plate to convert over to another motor? would like to have some more power????
many thanks
loren
92 montero rs 3.0 locked rear
Re: what can be bolted to a 92 montero trans? [Re: shawnsdad] #995584 04/30/10 05:07 AM
Pretty sure the only thing that bolts up is a Mitsu. There are past discussion on mix-n-match possibilities based on shaft diameters and spline counts. No idea where your 3.9 would fit in that matrix.
Just did a quick Google on it for specs. You could get a Mitsu 3.5 DOHC and get comparable, if not better performance. Nearly comparable with a 3.5 SOHC. I'm talking smack here, but I would think the cost of the time and effort to make what you have work would be equal to, if not greater than, the cost of finding a 3.5 and swapping it in.
Re: what can be bolted to a 92 montero trans? [Re: MontyMcV] #995585 04/30/10 07:46 AM
Anything that uses AW trans with removable bellhousing that matches. For example you could swap a jeep 4.0 if you could make that long engine fit in the engine bay or find something else that uses similar tansmissions like toyota or isuzu/gm trucks. Go to a junk yard that has transmissions inventoried, look for aisin transmissions and compare bellhousings.
Re: what can be bolted to a 92 montero trans? [Re: TOASTY] #995586 04/30/10 12:56 PM
mxmikie Offline
toyota
Re: what can be bolted to a 92 montero trans? [Re: TOASTY] #995587 04/30/10 02:24 PM
Well sure, if you're talking ATs, then have at it. <img src="/forums/images/graemlins/smile.gif" alt="" /> I forget not everyone is a handshaker! If I didn't have the 2.85s, maybe I'd become a convert myself...
Didn't FrankR post some thoughts a while back on the GM 3800 looking like it could mate up.?
Re: what can be bolted to a 92 montero trans? [Re: MontyMcV] #995588 04/30/10 08:26 PM
The Mitsu 6G75 3.8 will bolt up. See Nate's 3.5 into gen1 post in progress now...
Re: what can be bolted to a 92 montero trans? [Re: mxmikie] #995589 05/01/10 02:15 AM
what was the 3.8 mitsu. motor in? do the mitsu. FWD motors have the mounts for RWD? would love to find a 3000gt motor to slip in there. so much aftermarket stuff to build some HP. when I hit the gas I want to go a little quicker..
many thanks
loren
Re: what can be bolted to a 92 montero trans? [Re: shawnsdad] #995590 05/01/10 03:13 PM
does the 3.5 sohc or the dohc have that much more power? I was hoping for 200HP
many thanks
loren
Re: what can be bolted to a 92 montero trans? [Re: shawnsdad] #995591 05/01/10 03:33 PM
The 3.5l DOHC from 94-96 makes 215 hp in stock form.
The 3.8l is from the Gen 3.
Re: what can be bolted to a 92 montero trans? [Re: JohnnyBfromPeoria] #995592 05/01/10 07:01 PM
the dohc 3.5 should fit nice and pretty since its the same truck.....
many thanks
loren
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6287 MB (Peak: 0.7356 MB) Data Comp: Off Server Time: 2026-06-23 04:51:09 UTC
