Bumper Painting & Dual Exhaust #995745 05/03/10 12:31 AM
Everet Offline OP
Well, got tired of the faded, cracked, and overall junky look of the bumper on my 2 door, so I decided to paint it. I wanted it to be durable but couldn't find a good color match, so was going to paint it semi gloss black. Started sanding on it and realized that this bumper needed some work <img src="/forums/images/graemlins/scared.gif" alt="" />, and not being in the mood to make it perfect before paint <img src="/forums/images/graemlins/drunk.gif" alt="" />, I took another avenue. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Bought a can of Dupli-Color Truck Bed Coating.
Just left the bumper rough sanded and sprayed it on. It has a slightly textured semi-gloss finish. It hid the damage on the bumper and was able to paint the entire bumper with one $9.00 can <img src="/forums/images/graemlins/kewl.gif" alt="" />.
I think it turned out pretty good. I just went down and bought another can and will be doing the bottom of the doors and fender, giving it a 2-tone look. The stuff appears to be pretty tough.
I already scratched it and just touched it up....can't even see where, or remember where.
As an added option, the stuff dries pretty fast.
[Linked Image] [Linked Image]
Let me know what you think.
Re: Bumper Painting [Re: Everet] #995746 05/03/10 02:02 AM
DennisThompson Offline
Looks good, looks like it should have came from the factory that way. I used the same stuff on my new rear bumper. On my steel bumper you can still see a few flaws but not enough to worry about. I took pics but they turned out to dark so when I get better ones I will post them. I also plan on doing the rockers and my front bumper when I get a chance. Post pics when you get the rest done and also post pics on how your duel exhaust is done, that looks cool.
Dennis
Re: Bumper Painting [Re: DennisThompson] #995747 05/03/10 08:59 AM
Delarey Offline
Yes, I would also like to know how the dual exhaust was configured. Looks really nice. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Bumper Painting [Re: Delarey] #995748 05/03/10 03:34 PM
Everet Offline OP
Was having great difficulty with my welder so I'm buying a new one this week. Wire feed motor was surging along with the transformer dying.
Muffler is for a 2000 Chevy Camaro. Single inlet, dual outlet.
This one was manufactured by Thrush.
Bought some heavy duty hangers off a guy in Utah on ebay.
Now I just need to remove the stock muffler and put in a pipe with flanges on both ends so if I want I can go smaller than 2 inch if it looses bottom end torque due to too much flow.
Re: Bumper Painting [Re: Everet] #995749 05/03/10 04:02 PM
jaboo5322 Offline
And i would like to know how it sounds. Right now i have a glass pack with the exhaust exiting in front of the driverside rear wheel. Can be allittle anoying. But i have that same camaro muffler sitting in my garage i've been telling myself to do something like you did. <img src="/forums/images/graemlins/kewl.gif" alt="" />
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: Bumper Painting [Re: jaboo5322] #995750 05/09/10 04:09 PM
Everet Offline OP
With the stock muffler still in place it has a low rumble from idle to about 2300rpm. After that it is quiet. Was going to get a piece of exhaust tubing to replace muffler but found out that my mpg's just jumped 2+mpg's!!!
Will keep an eye on this and see if it is an anomaly. If indeed it did add 2+ mpg's, I'll leave the stock muffler on.
Will update this after a few tanks of gas.
Re: Bumper Painting [Re: Everet] #995751 05/10/10 05:44 AM
Everet Offline OP
Well, fixed my welder, by buying a Lincoln SP 200. It's a tank but couldn't pass it up for the deal I got it for. Came with 4 spools of wire, several tips, spare wire rollers, and a ton of other stuff.
Now I have to get it home...need some ramps to get it into the pickup...sucker must weigh 350 pounds.
Guess I'll have to read the instruction book.
Re: Bumper Painting [Re: Everet] #995752 05/10/10 12:53 PM
Sounds like a good deal, It should work out great for you.
Happy welding, Dennis
Re: Bumper Painting [Re: Everet] #995753 06/13/10 12:59 AM
Everet Offline OP
Well, MPG's went back to normal...just must have been driving like an old lady or didn't fill the tank <img src="/forums/images/graemlins/scared.gif" alt="" /> what a goof <img src="/forums/images/graemlins/zombie.gif" alt="" />
Anyway, took off the stock muffler and put in a 26" Cherry Bomb Glasspack...just as quiet as the stock muffler. So, put in a piece of exhaust tubing instead of the glasspack and now it's way too loud. <img src="/forums/images/graemlins/cyclops.gif" alt="" /> Am going to order a 12" Glasspack and install it next week.
Will keep you posted on progress.
Re: Bumper Painting [Re: Everet] #995754 06/15/10 09:00 AM
mattrodd Offline
I like the dual exhaust, my single flowmaster and my 215/75 tires brought my mpg to around 18 so you still beat me. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1996 Sportage EX 4x4
235/75/R15 Tires,
Flow Master
Lift from Everet
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6476 MB (Peak: 0.7719 MB) Data Comp: Off Server Time: 2026-10-22 00:10:03 UTC
