Seat won't "stand up" #995809 05/03/10 10:21 PM
The_Rusty_Gear Offline OP
I'm trying to get my drivers seat "upright" again. At the most "upright" lock it is still reclined, and I *know* that it used to sit up straighter (even the passenger seat does so)
Is this a comon problem? Did I strip something in the seat? has something shifted? What should I look for?
I'm not really digging the Lay-Z-Boy driving position.
1988 4Runner, V6 Auto, Mostly Stock
32 x 9.5 Swampers
Re: Seat won't "stand up" [Re: The_Rusty_Gear] #995810 05/04/10 12:41 AM
Snowtoy Offline
It sounds like you have stripped the gear teeth on the left side of the seat. This is usually caused when reclining the seat w/weight against the seat. and not pulling the lever up far enough. The same thing happened to me in my '90. If there is enough material left you might be able to smooth out the teeth, but it is unlikely. You will need to find a new gear set for it from a junk seat for a permanent fix. A quick short term fix(in my case it was 8yrs) position the seat in a comfortable position and drill a hole and use a bolt to lock the seat into place.
Re: Seat won't "stand up" [Re: Snowtoy] #995811 05/05/10 02:14 AM
missouriman Offline
the welds may have broken on the back of the seat loop.
big guy steered my wifes truck out after the fuel pump quit.
broke the welds on both sides.
pulled the custions off and re welded the lame factory welds.
good at new.
Re: Seat won't "stand up" [Re: Snowtoy] #995812 05/05/10 10:03 PM
Interesting fix! I may have to try that . . .
32 x 9.5 Swampers
Re: Seat won't "stand up" [Re: The_Rusty_Gear] #995813 05/06/10 04:10 PM
G
Greg_Canada Offline
My welds snapped too, did the same thing to fix, except i installed heated seat pads when i put it back together <img src="/forums/images/graemlins/smile.gif" alt="" />
89 4Runner
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6064 MB (Peak: 0.6712 MB) Data Comp: Off Server Time: 2026-11-18 11:54:51 UTC
