How to replace Ignition cylinder aka barrel Gen1
#995916
05/05/10 03:40 AM
My ignition key is loose and comes out while the rig is running, (sometimes handy) but I want a new tight cylinder. I've called the dealership and don't want to pay them. I think I found the part on rockauto but looking at mine when installed they snap the heads of the screws off for security. I've read that you cut a groove in there to get a flat blade in to remove them but they're recessed in, can't see that happening. Any ideas/experience?
1989 SWB V6 5 speed 230K
Re: How to replace Ignition cylinder aka barrel Gen1
[Re: BoiseMontero]
#995917
05/05/10 04:03 AM
the guy who owned my rig before me lost the key, so he drilled out bolts. I had a new cylinder put in, but I don't know what they used for bolts. him drilling it out didn't seem to cause any problems.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab '15 Subaru XV '03 BMW i325
[Re: zarktheshark]
#995918
05/05/10 04:37 AM
Either drill them out or drill a hole big enough for one of those special removers when you strip the head of a screw. I forget what they call them. They work well though!
1990 Montero LWB 3.0 Lodi, Ca. USA
[Re: Cambo]
#995919
05/05/10 07:39 AM
Ive done several of these. Usually I just use a punch, and spin them out. Couple of whacks to get them loose, and they come out by hand.
[Re: LandRaider]
#995920
05/05/10 08:01 AM
You can't replace the lock cylinder part itself? Seems like alot of work for what some cars is a 5 minute job. <img src="/forums/images/graemlins/frown.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#995921
05/06/10 04:56 PM
thanks guys for the help. I don't think I can replace just the cylinder, I can't see how to get it out without doing all of this, but of course I could be wrong <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: BoiseMontero]
#995922
11/04/10 05:33 PM
Just wanted to update this for anyone in the future. Landraider was right about getting the assembly off the column, then the real work started trying to get the old cylinder out of the assembly. There are a few spring pins that have to be pulled out, not punched through, I took it to a lock shop with my new cylinder, $20 and now it's all back in.
[Re: BoiseMontero]
#995923
11/04/10 06:19 PM
... Landraider was right about getting the assembly off the column, then the real work started trying to get the old cylinder out of the assembly.
I took it to a lock shop with my new cylinder, $20 and now it's all back in. Good to know. Let the pro's do it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: BoiseMontero]
#995924
11/05/10 12:11 AM
what was the part number ????
[Re: mxmikie]
#995925
11/11/10 12:49 AM
Just purchased a replacement ignition switch on Sat for the 96 from the local car parts place. Cost was $40 and when I opened the house brand box, it was an OEM mitsubishi switch. LOL.
Now to see if I can take it apart or if I'll have to get it started and drive it to a shop.
