Spool install #995947 05/05/10 06:38 PM
trcdrunner Offline OP
Well I finally got around to ordering that Spool - I gots to get out!!!
It showed, but no instructions - it looks pretty simple... BUT - Any tips/tricks I need to know?
Going into an open 4cyl dif.
Now this is going from memory (sitting here at work)
Guess I gotta dismantle the dif.
- Take ring off
- The side pieces (marking and checking)
- pull the spiders
Now does the spool just slide in, do I need to press anything on or bolt back down and good to go...
Also if anyone (Zuk) has the torque numbers it would be appreciated..
TIA
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Re: Spool install [Re: trcdrunner] #995948 05/05/10 06:41 PM
4Crawler Offline
Should be similar to the locker installs in the tech section:
- http://www.4x4wire.com/toyota/tech/detroit_locker/
Re: Spool install [Re: 4Crawler] #995949 05/05/10 07:34 PM
Adam F Offline
I just did one on a buddy's truck a few weeks ago.
You'll need a bearing separator and a press to get the carrier bearings off.
Everything I read said if you put the bearing adjusters back in the same amount of turns they came out, everything should be OK. It diddnt work out that way for us. We had to make some adjustments to get the preload correct. We used gear marking compound and a micrometer with a magnetic base. We put the bearings and ring gear in the over for a while, and they slid right back on without having to press them on.
97 4R, stock, daily driver
Re: Spool install [Re: Adam F] #995950 05/06/10 12:48 AM
HHMMM no separator... Did a couple lockrights a few years ago and guesstimated the bearing adjusters - all went fine... but those bearings... .....
Just gonna throw this out... Would you be willing to give a guy a hand?? I know your in Cincy (I'm on west side Bridgetown/Cheviot area) I'll grab a pizza and brews??!!??
aka FireNIce
TRCD Toys Web Site
TRCD Toys Apperal
Re: Spool install [Re: 4Crawler] #995951 05/06/10 04:22 AM
Thanks 4Crawler... forgot about the tech section... I did a search but didnt find "THIS"
aka FireNIce
TRCD Toys Web Site
TRCD Toys Apperal
Re: Spool install [Re: trcdrunner] #995952 05/06/10 05:24 AM
4Crawler Offline
Likely the search here only searches the forum threads. Just click on the "4x4Wire Toyota Section" link above, then there are loads of good articles on Tech, Maintenance and other topics.
Re: Spool install [Re: trcdrunner] #995953 05/06/10 05:37 AM
kewlynx Offline
Zuk's site if ya want to bug him.
www.gearinstalls.com <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: Spool install [Re: trcdrunner] #995954 05/09/10 01:07 AM
Adam F Offline
Sure! I'll help. I'm on the eastside though!
I have bearing separators and a press at work. If you get the carrier out and give it to me, I can take the bearings off one day at work.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6278 MB (Peak: 0.7274 MB) Data Comp: Off Server Time: 2026-07-15 00:21:01 UTC
