Need new radio antenna #995960 05/05/10 10:09 PM
The_Rusty_Gear Offline OP
My old antenna smapped off at the base. Are there any non-oem antennas out there? (I think "Toyota" antennas are $60 online - seems pricey)
1988 4Runner, V6 Auto, Mostly Stock
32 x 9.5 Swampers
Re: Need new radio antenna [Re: The_Rusty_Gear] #995961 05/07/10 01:30 AM
kewlynx Offline
None in your junkyards?
**ubi apis- ibi salus**
Re: Need new radio antenna [Re: The_Rusty_Gear] #995962 05/07/10 04:34 AM
bkg Offline
you need the mast or the base as well?
Brian K. Gallus
Re: Need new radio antenna [Re: kewlynx] #995963 05/07/10 02:38 PM
'nary a 'runner in the yards here . . . <img src="/forums/images/graemlins/frown.gif" alt="" />
32 x 9.5 Swampers
Re: Need new radio antenna [Re: bkg] #995964 05/07/10 02:40 PM
I'll have to take a closer look, but it just looks like the mast broke off. Does it screw into the base?
32 x 9.5 Swampers
Re: Need new radio antenna [Re: The_Rusty_Gear] #995965 05/07/10 03:19 PM
4Crawler Offline
Is it a power antenna? If so, see below:
- http://www.4crawler.com/4x4/CheapTricks/AntennaReplacement/index.html
Replacement masts run under $40 here in the US.
I am working on putting a short flexible antenna on my '85 to replace the power antenna. It is a little tricky as the stock mounting hole won't accommodate the aftermarket units I have tried to install due to the mounting angle and the inner fender wall behind the hole. Should have pictures and a writeup on the swap once it is done.
Re: Need new radio antenna [Re: The_Rusty_Gear] #995966 05/07/10 07:18 PM
bkg Offline
Yes - simple screw into the base. IIRC, the mast is male, the base is female...
I replaced the power antenna on my old 96 4Runner for < $40 from the dealer to a fixed mast. Still have a brand new mast (ended up with two for some reason) sitting in the garage. Should be an easy fix if it's just the mast.
Brian K. Gallus
Re: Need new radio antenna [Re: 4Crawler] #995967 05/07/10 07:25 PM
Nope. Not a power antenna. At least it never moved as long as I've owned the truck smile
32 x 9.5 Swampers
Re: Need new radio antenna [Re: bkg] #995968 05/07/10 07:30 PM
I just checked. The mast itself is broken, but when I took it off the base, the male portion of the base was also damaged. The top part of the male piece was only half there and there were only a couple of threads on the bottom that the antenna was hanging on to. By the lack of pieces falling out, I think it's been like that since I bought the truck 10+ years ago. There was also tons of grease packed in there ? ? ? ?
Soooooo, looks like the base is bad, but "good enough". If that mast stayed on for 10+years, I think I can get away with just relacing the mast!
32 x 9.5 Swampers
Re: Need new radio antenna [Re: The_Rusty_Gear] #995969 05/07/10 10:53 PM
ldivinag Offline
slap on a 31" stiff copper wire in that thing and weld it...
good to go. smile
why 31" that falls right in the middle of the FM band.
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6375 MB (Peak: 0.7613 MB) Data Comp: Off Server Time: 2026-11-02 12:26:10 UTC
