1989 3.0 V6 idle issues #995975 05/05/10 10:29 PM
Randy_NC Offline OP
I knew a 21 year old vehicle was going to need a few things. There is an issue with idle. when I first start the car cold it will idle high 1400-1800 rpm. After it warms up it will idle very low 300-500 rpm and will cut out some times. I did some searching and I would suspect the idle speed control servo. any suggestions?
Re: 1989 3.0 V6 idle issues [Re: Randy_NC] #995976 05/05/10 10:58 PM
Probably. Check out dsmisc.com for a decent price on the improved isc.
Re: 1989 3.0 V6 idle issues [Re: fasteddy] #995977 05/05/10 11:12 PM
Randy_NC Offline OP
it's not real clear on dsmisc.com's website which one fits my car.
Re: 1989 3.0 V6 idle issues [Re: Randy_NC] #995978 05/05/10 11:52 PM
call/email them and see what they say. IIRC, it's the 3.0 stealth model.
Re: 1989 3.0 V6 idle issues [Re: fasteddy] #995979 05/06/10 02:18 AM
toyhooter Offline
Score! The good info just keeps coming. Thanks for the dsmisc.com tip.
ToyHooter
90 LWB Montero
Sliders, Dual Bouncies, K&N, Flowmaster, Rancho Stabalizer, KYB Gas Adjusts,
ARB Compressor Under Hood, ARB Locker Waiting Garage Floor, Spare Tire Bike/CB Ant Mount
"I didn't do it, you didn't see me, you can't prove it."
Bart Simpson
Re: 1989 3.0 V6 idle issues [Re: toyhooter] #995980 05/06/10 03:41 AM
Yeah, they sell the improved all black plastic version that seems to be more durable. Make sure you get the oring, too...
Re: 1989 3.0 V6 idle issues [Re: fasteddy] #995981 05/06/10 03:52 AM
KrzyDav Offline
I got my lastest ICS from NAPA for like $110. It's the improved plastic one and may even be a repacked OEM <img src="/forums/images/graemlins/kewl.gif" alt="" />
dave h.
Re: 1989 3.0 V6 idle issues [Re: KrzyDav] #995982 05/06/10 08:04 AM
4ePikanini Offline
before purchasing extras I would check for
vacuum leaks
good connection on the coolant temp sensor
proper adjustment of the tps
clean connections on the Idle stepper motor
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: 1989 3.0 V6 idle issues [Re: 4ePikanini] #995983 05/06/10 05:25 PM
vacuum leaks-would cause high, not low, idle speed
good connection on the coolant temp sensor-base idle speed is too low as it is, and should be reset to about 650rpms with the isc disco'ed
proper adjustment of the tps-should make no diff except for the idle position switch, if any
clean connections on the Idle stepper motor-this is a maybe, but not as likely as the fried isc. I'd do the resistance tests before I bought a new one just in case
Re: 1989 3.0 V6 idle issues [Re: fasteddy] #995984 05/21/10 02:57 PM
W
wugwump Offline
i have a recently revived 91 3.0 LWB that i got an emission waiver sticker for this year in PA, but it idles high all the time, and the local chain shop couldn't figure out how to adjust it...plus the exhuast emissions are noxious, and will make me sick if i drive it for extended periods of time. tips? are the two related?
91 two-tone LWB 5-speed, sunroof, third row seat, 31" wrangler authority's on black cragar soft 8's.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6380 MB (Peak: 0.7450 MB) Data Comp: Off Server Time: 2026-06-23 01:17:27 UTC
