Gen 1 with rear disk brakes" Help" #996035 05/06/10 05:20 AM
Spider Offline OP
My 89 Gen1 Pajero is in need of rear disk brake pads. Does anyone have the Gen 1 factory disk set up on there rig and a North American parts supplier for these. Phil looked in his caps and came up with MB389570 as the part number. But I cant seem to find a cross referance for them anywhere.
89 Pajero 2.5 TD
Re: Gen 1 with rear disk brakes" Help" [Re: Spider] #996036 05/06/10 07:23 AM
4ePajero Offline
I have same model, and the only replacement pads I could find were Maxistop from Australia. I imported two sets.
If Maxistop is available in Canada, the part no is DB 8200 AE
NB.
Note the raised edges on the pads.
Some Gen2s use a similarly shaped pad, but without the raised edge. When these wear to a certain point, the pads fall out of the calliper! (been there, done that).
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: Gen 1 with rear disk brakes" Help" [Re: Spider] #996037 05/06/10 09:45 AM
LandRaider Offline
I'd look into montero sport brake pads. Maybe the earliest year they offered them in rear disks. I bet those would be the same as gen 1 rear disks
Re: Gen 1 with rear disk brakes" Help" [Re: LandRaider] #996038 05/06/10 07:53 PM
0778drz110 Offline
thats with leaf suspension though,
I'd try a 92 montero
Re: Gen 1 with rear disk brakes" Help" [Re: 0778drz110] #996039 05/07/10 02:19 AM
TrailRaider Offline
Try here. Not sure if they ship international and have never ordered from them. I found them while browsing around.
http://www.milneroffroad.com/categories.asp?cID=11414&p=2
'89 Raider V6 auto.
Re: Gen 1 with rear disk brakes" Help" [Re: TrailRaider] #996040 05/07/10 02:47 AM
PHIL_ Offline
Good link - Milner does ship int'l, one of our members from Ontario with a diesel used em a while back. Shipping is the killer though, so maybe to order some other small, hard to finds to reduce your eventual costs?
Did you try that guy I recommended out of BC, Pacific JDM Parts? He's been absolutely awesome to deal with. He gets your part numbers via chassis number, so I suspect he uses CAPs too... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Gen 1 with rear disk brakes" Help" [Re: PHIL_] #996041 05/07/10 06:24 AM
Spider Offline OP
Thanks for the help guys. Phil I havent tried you contact yet I was hoping to find something local before having to order some from Japan. Thanks 4ePajero for the tip on the tabs I found a set made by akebono that would fit but did not have the tabs. Good thing I didnt buy them. The one thing I have found is this set up was only used for 89-90 Pajero's. 91 gen 2 Pajero's have a different rear caliper. I might try and convert it all to the gen 2 set up. The search will continue.
89 Pajero 2.5 TD
Re: Gen 1 with rear disk brakes" Help" [Re: Spider] #996042 05/07/10 01:49 PM
Is your rear locked now? If not, maybe the effort would be better put towards getting a Gen II locked rear?
Re: Gen 1 with rear disk brakes" Help" [Re: Spider] #996043 05/07/10 02:33 PM
PHIL_ Offline
My contact is in BC. But I'd probably upgrade the calipers too, if you're hanging onto the rig, so you avoid this next time... I can take measurements for you if you want?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6288 MB (Peak: 0.7326 MB) Data Comp: Off Server Time: 2026-05-29 22:21:18 UTC
