Stuck idler arm #996079 05/07/10 01:59 AM
mattpdx Offline OP
Trying to replace the idler arm, but I can't seem to separate it from the steering link. I've been using a tie rod separator (same thing as pickle fork, I think), but that thing seems stuck stuck stuck.
Any ideas for getting it loose?
Thanks,
Matt
Re: Stuck idler arm [Re: mattpdx] #996080 05/07/10 05:15 AM
OOP'S Offline
Soak it down with good penetrating oil like PB Blaster or Koil. Not WD-40
Get a TRE tool removal tool, I got mine at Harbor freight for about ten dollars, pickle forks put a bind on the joint and you will destroy the TRE.
I was taught another method by a Toyota team leader and it works. Here is a picture.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Stuck idler arm [Re: OOP'S] #996081 05/11/10 09:20 PM
mattpdx Offline OP
Couldn't get it to pop out with the two hammers, but the TRE remover did the trick. Thanks for the help!
--Matt
Re: Stuck idler arm [Re: mattpdx] #996082 05/11/10 11:37 PM
RatLabGuy Offline
--Matt
That's definitely one of those tools that, looking back, was well worth the $15. I find myself using it a lot.
BTW in a pinch, a gear puller can aften be used to do the same thing.
Question Reality.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6005 MB (Peak: 0.6562 MB) Data Comp: Off Server Time: 2026-06-10 01:54:54 UTC
