ECU part number issue #996550 05/10/10 11:19 PM
Karathos Offline OP
I have a 2.0 DOHC engine that i am swapping into my mazda truck, Unfortunatly the wiring harness only has one o2 sensor and does not have a air intake temp sensor. My 98 sportage has 2 o2's and a Air intake temp sensor. Could someone please tell me what year had only one 02 and also what part number for the ecu i need?
Thank you
Ryan
98 Sportage 3" lift 31" Superswampers
88 B2200 Soon to have 2.0 kia engine
Re: ECU part number issue [Re: Karathos] #996551 05/11/10 12:18 AM
DennisThompson Offline
My 95 DOHC only has 1 o2 and the 96 my Boy pulled the engine out of only had 1 also. AS far as I know the BODIs had 1 o2 and the OBDIIs had 2. The Part# on mine is (K03Y OBDI). The other # on it under the BOSCH logo is (0 261 230 894).
Hope this helps, Dennis
Re: ECU part number issue [Re: DennisThompson] #996552 05/11/10 02:34 AM
Karathos Offline OP
Well that does help a bit, It seems like i am starting to get somewhere now. Could you tell me, if you 95's ECU is an 88 pin ecu? And does it say motronic across it? I know its an odd question, But i am having TONS of trouble finding an OBD1 ecu.
Anyone here have an OBD1 ECU they are willing to part with?
Re: ECU part number issue [Re: Karathos] #996553 05/11/10 12:45 PM
Mine does have MOTRONIC on the case but it has 55 pins, 2 rows of 18 and 1 row of 19 pins. I know where one might be, my boy pulled an engine out of a 96 in the wrecking yard and didn't take the ECU. Wensdays is 1/2 price, I could go pick it up and you could paypal me the money. PM or email me if you want me to see if its still there.
Dennis
Re: ECU part number issue [Re: DennisThompson] #996554 05/11/10 03:02 PM
Karathos Offline OP
I have the 88 pin harness, If you could get me one i would pay for it, Any idea how much they charge? Getting the 96 ecu would save me a Ton of hassle.
Let me know, And thanks again
Re: ECU part number issue [Re: Karathos] #996555 05/11/10 04:57 PM
I will go check tomorrow after work, if it's the 55 pin I won't pick it up, It it's 88 I will get it for you. I think the charge about $100.00 for an ECU so if I can get it 1/2 price it will be about $50.00.
Dennis
Re: ECU part number issue [Re: DennisThompson] #996556 05/11/10 09:30 PM
Karathos Offline OP
If you can get it for 55 plus whatever it takes to ship it to PA i'll take it, thank you for your time.
Re: ECU part number issue [Re: Karathos] #996557 05/12/10 09:47 PM
I called the wrecking yard to get a price and they said the ECU was gone and they don't have another Sportage. My boy and and his friend go to wrecking yards alot, I will have them keep an eye out.
Good luck with your project and keep us posted, Dennis
Re: ECU part number issue [Re: DennisThompson] #996558 05/12/10 11:12 PM
Karathos Offline OP
Well thank you for looking, and please keep an eye out, thanks again and i Will keep everyone posted on the build
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6225 MB (Peak: 0.7091 MB) Data Comp: Off Server Time: 2026-10-26 11:31:58 UTC
