Transmission exchange #996647 05/11/10 11:12 PM
O
opusthe2nd Offline OP
Will a 94 Toyota 2wd truck 5 spd, swap into a 86 2wd truck straight across? 22re is the 94 and 22r is the 86.
Re: Transmission exchange [Re: opusthe2nd] #996648 05/13/10 04:31 AM
O
Ok, seeing that question got me nowhere. smile Is an 86, 5spd, 2wd transmission the same transmission as a 4wd transmission?
Re: Transmission exchange [Re: opusthe2nd] #996649 05/13/10 04:46 AM
4Crawler Offline
No, the 2WD has a tail housing for the rear drive shaft to slip into. The 4WD box has a mating flange for the transfer case to bolt to. Not sure if the tail housing can be swapped or not.
Re: Transmission exchange [Re: 4Crawler] #996650 05/16/10 09:20 PM
O
Ugh! Thanks.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6007 MB (Peak: 0.6562 MB) Data Comp: Off Server Time: 2026-07-16 03:26:56 UTC
