Crankshaft Pully Nut question.
#997341
05/19/10 02:04 AM
Whats the deal with the crankshaft pully nut removal. I read the tech threads and I see that it's dificult to remove. Do you need to remove it for a timing belt job? I was thinking that it would only be a problem if I was pulling/rebuilding the engine.
ToyHooter 90 LWB Montero Sliders, Dual Bouncies, K&N, Flowmaster, Rancho Stabalizer, KYB Gas Adjusts, ARB Compressor Under Hood, ARB Locker Waiting Garage Floor, Spare Tire Bike/CB Ant Mount
"I didn't do it, you didn't see me, you can't prove it." Bart Simpson
Re: Crankshaft Pully Nut question.
[Re: toyhooter]
#997342
05/19/10 04:46 AM
You have to take it off the get the lower timing belt cover off to replace the timing belt. It's easy to get off. Just use a half inch breaker bar and rest it on the frame rail and do a light bump on the starter, and it comes loose. Torqing it back down requires some way to hold the pulley/crank still while you honk on the wrench, or cheat and bash the tightening wrench with a dead blow hammer.
[Re: fasteddy]
#997343
05/19/10 06:15 AM
I see. That really bites. Dealer maintenance engineering. Like jacking up the engine to get to a few plugs. Or using a special tool that resembles an alien probe to get to a few plugs. Thanks.
[Re: toyhooter]
#997344
05/19/10 07:22 AM
Some pulleys have two holes for a "Special Tool" that you insert into the holes to hold it still while tightening the bolt. If you have a welder you can make it with a couple of bolts, a grinder and a piece of angle iron. Others here have made one with a couple of pieces of flat stock bolted together. Or you can use a chain wrench and piece of belt to cushion the chain.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: toyhooter]
#997345
05/20/10 12:53 AM
Cool. Thanks for all the info. Saved and printed.
