sye and cv #997372 05/19/10 03:36 AM
tcoff Offline OP
any suggestion on a sye and cv drive shaft? i was looking at the one from advance adaptors for the sye. and is there anything else i would need? also how do i determin the right size for the new driveshaft. would i have to use shims at all on the rear axle?
99 wrangler sport, auto. 2.5 inch lift, 31 MTR's
Re: sye and cv [Re: tcoff] #997373 05/19/10 03:51 AM
4x4Wire Offline
There are two points I have found:
1. Drive line angle. Which ever SYE you get, there will be a change in driveshaft length. That change, coupled with any lift, will change your driveline angle. Shims are the quick and easy fix. However, shims may not be enough. In that case, relocation of spring perches is necessary. And, if you go with shims, use steel shims (check Pro-Comp for their shims). Most shims are aluminum and (IMHO) will not last.
2. Rear axle drop. Keep in mind that the CV joint has a centering pin that is only about 3/8 inches in diameter. It will break if you are in a situation where full axle drop puts full weight load on the CV joint. I broke 2 within a 2 month period. Now I have limiter straps so that axle drop is limited to keep full weight off of the centering pin.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: sye and cv [Re: 4x4Wire] #997374 05/19/10 01:05 PM
superdawg Offline
TJ with coil springs? No leafs
2.5" lift...no problem.
You have to install the sye first, then with the jeep on its weight (not jacked up or on a lift)measure for the d shaft.
1310 CV series to 1310 pinion yoke series. Use a driveline shop that regularly builds shafts for jeeps and SYE kits.
Unless you have more lift than 2.5" adjusting the pinion up is not needed at all. Yes, even at full droop.
SD
Re: sye and cv [Re: superdawg] #997375 05/24/10 03:01 AM
tcoff Offline OP
"1310 CV series to 1310 pinion yoke series" so is this the model type i should be looking for?
Also i'm looking at the sye and it says "may require mode fork shift rail to be shortened" ok one whats that, and two is it obvious to determin if this needs to be done?
Thanks for the help.
tom
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6002 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-07-13 21:22:23 UTC
