yj frame swap #997498 05/20/10 10:34 AM
dreamjeep Offline OP
i've got 89 yj with a bad frame i found a 76 cj7 it looks different but the seller said it would work dose anyone know for sure
Re: yj frame swap [Re: dreamjeep] #997499 05/20/10 11:43 AM
sunder Offline
It's substantially different. If you're a good fabricator you can probably make it work...
91 YJ
2 Seater Sand Rail
Handfull of other fun toys...
And a brand new, spit shined, B.S.
Oh, and a job to boot.
Re: yj frame swap [Re: sunder] #997500 05/20/10 01:24 PM
superdawg Offline
CJ7 frames are weak junk compared to a YJ frame. Mounting points for everything are different. Don't do it.
SD
Re: yj frame swap [Re: dreamjeep] #997501 05/22/10 03:03 PM
MartySoCal Offline
You need another YJ frame!
If you find one, make sure it matches the engine you have in your '89. Six cylinder frames are different than four cylinder frames, the engine mount brackets are welded to the frame in different spots. '87-'95 are the years that will fit.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6001 MB (Peak: 0.6551 MB) Data Comp: Off Server Time: 2026-06-18 13:10:22 UTC
