yj frame swap
#997498
05/20/10 10:34 AM
i've got 89 yj with a bad frame i found a 76 cj7 it looks different but the seller said it would work dose anyone know for sure
Re: yj frame swap
[Re: dreamjeep]
#997499
05/20/10 11:43 AM
It's substantially different. If you're a good fabricator you can probably make it work...
91 YJ 2 Seater Sand Rail Handfull of other fun toys... And a brand new, spit shined, B.S. Oh, and a job to boot.
Re: yj frame swap
[Re: sunder]
#997500
05/20/10 01:24 PM
CJ7 frames are weak junk compared to a YJ frame. Mounting points for everything are different. Don't do it.
SD
Re: yj frame swap
[Re: dreamjeep]
#997501
05/22/10 03:03 PM
You need another YJ frame!
If you find one, make sure it matches the engine you have in your '89. Six cylinder frames are different than four cylinder frames, the engine mount brackets are welded to the frame in different spots. '87-'95 are the years that will fit.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6008 MB (Peak: 0.6557 MB) Data Comp: Off Server Time: 2026-06-07 04:18:45 UTCValid HTML 5 and Valid CSS
