Replacing fuel pump #997565 05/20/10 11:50 PM
PCMONT Offline OP
My truck died yesterday. Came out from convience store and she wouldnt fire up. Luckily there was a service shop next door and they said i was the pump and wanted 300.00 for repair. I told them i would handle it and autozone has one for 99.00. I looked at the FSM and it seem's fairly straight forward. Anyone run into any issues replacing theirs ??? Im going to tackle it 2morrow night.
Chris
91 LWB 3.0 w/300K. Nothing fancy yet...still getting the quirks out and cosmetic fixes.
Re: Replacing fuel pump [Re: PCMONT] #997566 05/21/10 12:23 AM
Va_Stumpy Offline
Well , that seems to be the only thing on mine that hasn't failed. After repairs; my alternator is alternating; my starter is starting, & my pistons are pissing. It seems to be pretty straight forward based on the post I've read. If it's not ,I'm sure there are knowledgeable members to guide you. <img src="/forums/images/graemlins/lol.gif" alt="" />
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Replacing fuel pump [Re: Va_Stumpy] #997567 05/21/10 04:25 AM
You need a set of flare nut wrenches to safely loosen the fuel line connectors. Only one end is a swivel connector. Otherwise straightforward...
Re: Replacing fuel pump [Re: PCMONT] #997568 05/24/10 03:25 PM
MI_Mitsu Offline
Here in the midwest, those fuel lines are prime for corrosion. Severe corrosion.
Be prepared to soak the line connections overnight first using penetrating fluid or brake fluid.
Worst case scenario is you may have to also buy a new flex line going to the sending unit, a new sending unit (prime for corrosion also), sending unit gasket, pick-up tube sock.
When accessing the sending unit through the access hatch in the rear cargo area, take care not to damage the access door gasket - it's obsolete from Mitsu. If it's bad you'll have to cut a new one.
Jim
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.005s) Memory: 0.6016 MB (Peak: 0.6574 MB) Data Comp: Off Server Time: 2026-05-30 01:07:07 UTC
