Steering Stabilizer upgrade
#997934
05/23/10 08:03 PM
It time to replace ym steering stabilizer, and after a quick search online, I found 2 options that are above stock. One is a single shock, the other a double shock kit. I was wondering what everyone else is using and if you think its worth it. (Single shock kit =$90, double kit= $165)
Re: Steering Stabilizer upgrade
[Re: toyT100]
#997935
05/24/10 03:42 AM
I guess it would come down to how much off-roading you do...most have the single setup. <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: BamZipPow]
#997936
05/24/10 05:14 PM
I run a single Rancho 5402 which is made for a Dodge 3/4 ton. i had to place a bracket above and to the side of the stock bracket, using the idler arm mounting bolts, as the rancho stablilizer is about an inch larger in diameter compared to the stock stablizer.
formerly 277000_yota Old enough to know better, but still to damn arrogant to care... ]www.cardomain.com/ride/2614269'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P) '98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
[Re: toyT100]
#997937
05/26/10 05:41 PM
I have factory 31" tires and run the Monroe single replacement from NAPA, smooth as silk and way better than stock screen door damper.
Jeff 96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
[Re: jmoser]
#997938
05/27/10 05:44 AM
Im runnin 35's w a 3"BL and BJ spacers so somethin more than stock is gonna be needed i think
[Re: toyT100]
#997939
05/27/10 02:30 PM
Im runnin 35's w a 3"BL and BJ spacers so somethin more than stock is gonna be needed i think You have yer answer then... <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: BamZipPow]
#997940
05/27/10 04:26 PM
I use a single (and now worn out) Rancho for a Chevy, but the thing that helped lessen my steering feedback the most was unloading my tsls for pitbulls.
~Adam  96 T100: D44, lockers and stuff
