Steering Stabilizer upgrade #997934 05/23/10 08:03 PM
toyT100 Offline OP
It time to replace ym steering stabilizer, and after a quick search online, I found 2 options that are above stock. One is a single shock, the other a double shock kit. I was wondering what everyone else is using and if you think its worth it. (Single shock kit =$90, double kit= $165)
Re: Steering Stabilizer upgrade [Re: toyT100] #997935 05/24/10 03:42 AM
BamZipPow Offline
I guess it would come down to how much off-roading you do...most have the single setup. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Steering Stabilizer upgrade [Re: BamZipPow] #997936 05/24/10 05:14 PM
IceBlueT Offline
I run a single Rancho 5402 which is made for a Dodge 3/4 ton. i had to place a bracket above and to the side of the stock bracket, using the idler arm mounting bolts, as the rancho stablilizer is about an inch larger in diameter compared to the stock stablizer.
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: Steering Stabilizer upgrade [Re: toyT100] #997937 05/26/10 05:41 PM
jmoser Offline
I have factory 31" tires and run the Monroe single replacement from NAPA, smooth as silk and way better than stock screen door damper.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: Steering Stabilizer upgrade [Re: jmoser] #997938 05/27/10 05:44 AM
toyT100 Offline OP
Im runnin 35's w a 3"BL and BJ spacers so somethin more than stock is gonna be needed i think
Re: Steering Stabilizer upgrade [Re: toyT100] #997939 05/27/10 02:30 PM
BamZipPow Offline
You have yer answer then... <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Steering Stabilizer upgrade [Re: BamZipPow] #997940 05/27/10 04:26 PM
adam Offline
I use a single (and now worn out) Rancho for a Chevy, but the thing that helped lessen my steering feedback the most was unloading my tsls for pitbulls.
~Adam
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6176 MB (Peak: 0.6913 MB) Data Comp: Off Server Time: 2026-05-29 15:16:21 UTC
