Rating: 5
SO AM I CORRECT IN MY RESERCH? #998079 05/25/10 05:43 AM
8
80D50SPORT Offline OP
HEY GUYS ,
FROM WHAT I HAVE READ .. I THINK THE 2G 92 UP MONTY SPORT UPPER CONTROL ARMS WILL SWAP ON TO A 1G 4CYL SWB RIGHT? I READ THEY ALLOW FROM MORE CAMBER ADJUSTMENT WITH A TORISON BAR CRANK .BUT WHAT IF YOU AREN'T RUNNING THEM CRANKED ?I FOUND A GREAT DEAL ON A SET OF UPPER ARMS FROM A GUY HEAR. HE HAD THE SHAFTS AND BALL JOINTS REPLACED DAYS BEFORE THE MOTOR NUKED AND NOW HE IS PARTING THE TRUCK OUT HEAR LOCALLY..ALSO IS THERE ANYTHING ELSE I COULD USE/SHOULD GET FROM HIM ? IT'S A 92 MONTY SPORT FROM WHAT HE TOLD ME ..
Re: SO AM I CORRECT IN MY RESERCH? [Re: 80D50SPORT] #998080 05/25/10 06:13 AM
xFezx Offline
I didn't think they made sports till later in the 90s
You can call me Fez
'95 SR 15x8 steel rims w/ 33x12.5 Duratracs, cranked torsion bars, "Baja" lights
'09 Nissan Sentra SR
Re: SO AM I CORRECT IN MY RESERCH? [Re: xFezx] #998081 05/25/10 01:34 PM
sparkem Offline
Sports were not around until 96 I think. Yes the Gen2 upper control arm will swap onto your gen1 4 cyl. If you can figure out the search here, a few people have done the swap.
Please don't type in all caps.
Re: SO AM I CORRECT IN MY RESEARCH? [Re: sparkem] #998082 05/25/10 04:26 PM
zarktheshark Offline
on a 92,you can take the UCA's, but if you are not going to crank your TB's, the only real benifit is some added beefiness and bolt on ball joints vs the pressed in gen1. You will have to get an alignment after the swap. Some on here have swapped the whole front end. I am pretty sure you can use the front disks brakes and master cylinder with slight mods. I think there is a gen1 gen2 compatability thread stickied.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: SO AM I CORRECT IN MY RESERCH? [Re: 80D50SPORT] #998083 05/25/10 04:35 PM
Grasscat Offline
HEY GUYS ,
Why are you shouting?
also
Have you read this?
Michael j
TreadLightly! Trainer
Re: SO AM I CORRECT IN MY RESERCH? [Re: Grasscat] #998084 05/25/10 04:42 PM
also
Have you read this?
On the 4x4wire, we only use ALL CAPS when we shout or want to highlight a part of what we're saying.
To answer your question if it's still not clear, the gen II Montero (not sure about the sport) has been shown to have an Upper Control Arm (UCA) that can be swapped into the gen I Montero/Raider to improve the CV joint angle and hopefully lengthen it's life.
Also to clarify, early 2 door 1st gen Montero's (84-90) were sometimes called Montero Sports.
The later Montero Sport which has a completely different body style than the same year Montero is a US only naming convention & was not built and sold in all countries like the Montero was. In countries where it was sold it was either called the Montero Sport or the Mitsubishi Challenger.
Re: SO AM I CORRECT IN MY RESERCH? [Re: off-roader] #998085 05/25/10 07:30 PM
These would have come with the LSD, bouncy seat, stainless and chrome trims, metal door mirrors, upscaled wheels, and other year specific things like rear gate power lock, rear wiper and washer.
<img src="/forums/images/graemlins/wink.gif" alt="" />
Re: SO AM I CORRECT IN MY RESERCH? [Re: 80D50SPORT] #998086 05/25/10 11:24 PM
8
Sorry about the all caps it was late night for me last night. I have serched and came up with the info i posted and i have read most of the compatabilty thread but it seems to jump around and the whole 6cyl this 4cyl that thing is confusing. Thanks for the info and quick responses.
Re: SO AM I CORRECT IN MY RESERCH? [Re: 80D50SPORT] #998087 05/26/10 12:58 AM
Dude, I'm over in Biluxi/Gulfport for a month or so for the "oil spill <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> " , maybe I could lend a hand dependant on my work schedule.
Re: SO AM I CORRECT IN MY RESERCH? [Re: 80D50SPORT] #998088 05/26/10 12:58 AM
It's ok. We understand. You're from Alabama. Roll Tide. Born and raised there myself. And if you are about to come back at me with a War Eagle, you can kiss my .......
<img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6434 MB (Peak: 0.7687 MB) Data Comp: Off Server Time: 2026-06-17 12:01:36 UTC
