Rubber Windshield Gasket/Trim? #998219 05/27/10 04:39 AM
masheen Offline OP
According to the local Toyota dealer, '83 to March '89 trucks use the same windshield. Anyone know if there's a "windshield gasket" similar to the one used on the back window that can be used to replace the trim? I want to rid myself of the windshield trim pieces and achieve a cleaner look more reminiscent of the newer vehicles. I've looked through the archives and seen this question asked before, but no answers. Geez, hope I'm clear enough on what I'm looking for......
85 4x4,22r Carb, BFG 33x12.5/15x10 Rocket Startrack rims, 2" Body Lift, Rancho Springs(3"f/2"r), stabilizer & adj tork rod, Skyjacker adj drag link ,Bilstein shox, Line-x'd where it counts, KC HiLites, grill guard, roll bar, dual quad rear bumper.
Re: Rubber Windshield Gasket/Trim? [Re: masheen] #998220 05/27/10 05:16 AM
kewlynx Offline
Not that I've ever seen. Better folks to ask might be a professional glass or body shop if there's anyone in your area.
Seemed to me someone fudged a window fix with some bondo or JBWeld.
Do bear in mind this is a safety item, so that's your other consideration in your quest.
**ubi apis- ibi salus**
Re: Rubber Windshield Gasket/Trim? [Re: kewlynx] #998221 05/27/10 05:28 AM
4Crawler Offline
A thread over on Yotatech has some options:
- http://www.yotatech.com/f116/eliminating-metal-windshield-trim-aka-rust-maker-107858/
Including what I did:
- http://www.4crawler.com/4x4/CheapTricks/WindshieldTrim/index.html
On the '84 and later trucks, the windshield is glued into the frame and the trim is merely cosmetic, just some metal pieces that snap into the gap between the glass and body.
Re: Rubber Windshield Gasket/Trim? [Re: 4Crawler] #998222 06/02/10 06:02 AM
masheen Offline OP
Kewlynx, yep I know that windshield mounting is definitely a safety issue and it also helps structurally as well. I haven't researched newer vehicles to see if car manufacturers are utilizing a one piece gasket/trim combo setup.
4Crawler, I looked at your solution and had considered doing that. Looks pretty darn good! Then you posted the link to the Yotatech thread!!
As I read through it, one guy found a Toyota weatherstrip used in Japanese Hilux minipickup from 1984 to 1988. He says it's a perfect fit. The Toyota p/n is 56121-89117. Here's a link to an Aussie site that has it for about $45 + $9 shipping:
http://www.4x4world.com.au/shopping/product_details.modal.php?id=1265556&product_id=5996
I'm gonna check on this tomorrow at the Toyota dealer just to be sure. I'd probably go with the butyl rubber along with the gasket, but I'm gonna let the glass shop make the call on that one.
Thanks for the info guys!
Re: Rubber Windshield Gasket/Trim? [Re: masheen] #998223 07/27/10 08:13 PM
masheen Offline OP
Make that $45 for shipping to the US! I've had no luck going through Toyota Corporate US. I thought that maybe Toyota in Japan might be able to ship one or more of these seals. My Toyota parts guy, who passed away last year, had gotten several parts for me before from Japan. Now without his resources and wealth of knowledge, this seems impossible. I miss ya Larry! Rest in peace brother!!
Re: Rubber Windshield Gasket/Trim? [Re: masheen] #998224 07/27/10 09:45 PM
OOP'S Offline
They do make a rubber trim that takes the place of the S.S. trim pieces. They used it on mine after I replaced the top on my rig. It pushes into the gap that is left from the S.S. trim. I had my windshield replace at a lass shop at the local P-N-P. Any glass shop should have it.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6123 MB (Peak: 0.6992 MB) Data Comp: Off Server Time: 2026-07-13 18:30:12 UTC
