8in HP 5.29 gears #998921 06/03/10 12:58 AM
1
1986powerram50 Offline OP
Guy on outerlimits is thinking really hard bout getting some made. If your interested might wanna speak up I told him id take 2 if it goes thru.
http://www.outerlimits4x4.com/viewtopic.php?p=1901375#1901375
--keRby
Ad Inexplorta
Re: 8in HP 5.29 gears [Re: 1986powerram50] #998922 06/03/10 05:03 PM
That would be sweet especially now since the 5.29 can be had for the 9.5 rear end. I'm poor otherwise i'd be in.
Re: 8in HP 5.29 gears [Re: TOASTY] #998923 06/03/10 06:01 PM
Alex Kogan Offline
What's the source/part #, did I miss something? or is it a tale of Mitsu Canter again?
08 PowerWagon (stock!)
Re: 8in HP 5.29 gears [Re: Alex Kogan] #998924 06/03/10 06:16 PM
1
The 9in gears work in the 9.5
--keRby
Ad Inexplorta
Re: 8in HP 5.29 gears [Re: 1986powerram50] #998925 06/07/10 04:28 PM
tribolas Offline
I'm the guy...
Is there any interest in these gears ?
High pinion 5.29 for the 8" front diffs.Mitsubishi do NOT make them.
They can work with both 9" and 9.5" rear diffs because the 5.29 rear gears for the 9" also fits the 9.5".
I tested it and it is 100% compatible.
_________[...PART TIME REBEL...]_________
http://www.youtube.com/watch?v=UAiNfq_k1r4
Re: 8in HP 5.29 gears [Re: tribolas] #998926 06/07/10 06:10 PM
I'm sorta interested. My dilemma is to go with 4.90's (proven, right size) or these 5.29's (unproven custom cut fronts, and smaller/weaker? rears).
What do the rest of you guys think? Wouldn't the smaller 9" rear be weaker than a true 9..5" rear end? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 8in HP 5.29 gears [Re: off-roader] #998927 06/08/10 11:50 AM
tribolas Offline
The main difference between the 9" and 9.5" rear diffs is in the drive shaft diameter. This is where you must focus for reliability issues.
The difference between 5.29 and 4.90 ratio is 8%.
To get an idea , if you have 5,29 and 31" tires changing to 4.90 ratio you must go with 29" tires to get the same results.
Re: 8in HP 5.29 gears [Re: tribolas] #998928 06/08/10 04:36 PM
what about just using the LP 8" front to get 5.29's in the front?
Re: 8in HP 5.29 gears [Re: TOASTY] #998929 06/08/10 05:04 PM
tribolas Offline
It's possible.
If you have an 8" HP front diff you can replace it with an 8" LP and use MB241981 (5.29) gears.
With these HP gears you will need ONLY the gears.No propshaft and bracket modifications.
Re: 8in HP 5.29 gears [Re: TOASTY] #998930 06/08/10 05:07 PM
zarktheshark Offline
Question, the 97 MS used a 9" rear, right? I did that swap last year. I have the small front diff right now, but I can get the 8" front from Curt I bet (stock 89 v6). is the that 8" a HP or LP? My rig could really use some help turning my 34's.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6405 MB (Peak: 0.7656 MB) Data Comp: Off Server Time: 2026-06-23 11:14:32 UTC
