Dual gas tanks? #998994 06/03/10 05:25 AM
BamZipPow Offline OP
Ever since the 1993 T-100 got hydrolocked by the wife, I got to thinking...putting dual gas tanks on the 1998 T-100 by using the 1993 tank (passenger side fill) and fitting it in.
I know I should be able to use the same front support setup, weld in a pin holder fer the rear inside strap support. The rear outer support is already in place with the emergency brake bracket. <img src="/forums/images/graemlins/smile.gif" alt="" />
Has anyone on here put in dual tanks on their T-100? I searched in here but didn't find anything. I'm sure there had to be someone who did it... <img src="/forums/images/graemlins/smile.gif" alt="" />
Yes...I know I'd have to re-route the exhaust system closer to the driveline and put a low profile muffler near the rear tire holder. Any thoughts? <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Dual gas tanks? [Re: BamZipPow] #998995 06/04/10 03:22 AM
Squeezer99 Offline
how about you just give me the 93 as-is, i'll throw in another 3.0L v6 in it and be happy smile
Re: Dual gas tanks? [Re: Squeezer99] #998996 06/04/10 05:12 AM
Are you near Houston?
Make me an offer via PM. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Dual gas tanks? [Re: BamZipPow] #998997 06/04/10 07:34 AM
fishy97t100 Offline
you're gonna have to lose the storage compartment for the jack under the seat....to clear the tank
1997 T100 SR5 xxcab 4WD 5spd D44, AAM 11.5, dual case
Re: Dual gas tanks? [Re: fishy97t100] #998998 06/04/10 02:59 PM
Losing the spot under the passenger side fer the jack wouldn't be a problem. I'll just move the jack to the driver's side. <img src="/forums/images/graemlins/smile.gif" alt="" />
Looks great. Got any other tips/help installing the duals? What other methods/tanks did you consider? Got any other piccies? How did you setup the fuel/return lines? How do you switch the tanks?
I guess I could even go with another extended cab gas tank and route the filler neck to the original spot... <img src="/forums/images/graemlins/wink.gif" alt="" />
Looks like I can pick up a local tank from about $45 to $100. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Dual gas tanks? [Re: fishy97t100] #998999 06/08/10 05:53 AM
Creeper Offline
Oh my, that's hawt ... in a T100 kinda way.
'97 T100 SR5 XCab 4WD
TRD SC ~ ARB ~ FWC
'85 FJ60 Landcruiser
4E9 ~ locked ~ 33's
Re: Dual gas tanks? [Re: Creeper] #999000 06/09/10 02:35 PM
fishy97t100 Offline
fyi:
93-94 passenger side fuel tank
95-98 driver side
Fuel tanks that came from 4wd are slightly taller
[Linked Image] [Linked Image]
custom hanger, oem fuel tank straps, modified fuel filler
Aux tank feeds the main tank through the modified filler. The fuel pump is activated by a switch, return line is also connected on the modified filler, evap line spliced. I have a custom bed and chose the driver side fill for the aux tank...extended fuel hose
Re: Dual gas tanks? [Re: BamZipPow] #999001 06/10/10 11:27 PM
Squeezer99 Offline
I'm about 6 hours away smile
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6245 MB (Peak: 0.7259 MB) Data Comp: Off Server Time: 2026-10-21 20:41:42 UTC
