1991 montero 3.0L does not have an EGR valve. I think? #999002 06/03/10 05:54 AM
canyonrc28 Offline OP
Howdy, folks.
My 1991 gen 1 Montero did not pass emissions. My first thought was to clean or replace the EGR valve. I looked up, down, side and around and it appears there isn't one. This is a fuel injected engine. I went to a friend's house and found that his Gen 1 has one is in plain view. What gives? Any insight on the issue? Is this a commonality with these vehicles? I just bought it, so, I would appreciate the education. Thanks.
I am a walrus.
Re: 1991 montero 3.0L does not have an EGR valve. I think? [Re: canyonrc28] #999003 06/03/10 07:49 AM
Welcome to the 4x4Wire!
I think the EGR valve is located along the left hand side (drivers side) on the lower plenum portion of the intake manifold. I have 2 89s and 2 90s in the yard, but have not confirmed the latter have EGR valves. Both 89s are so equipped.
Cheers,
Russell
Re: 1991 montero 3.0L does not have an EGR valve. I think? [Re: canyonrc28] #999004 06/03/10 02:01 PM
WigWiggy Offline
My 91 3.0 did not have an EGR system either from what I could tell. I looked all over for it when it failed NOx emissions.
98 Montero, 184k.
Re: 1991 montero 3.0L does not have an EGR valve. I think? [Re: WigWiggy] #999005 06/03/10 02:23 PM
justice Offline
the 89 3.0's have EGR. 90 and 91 do not.
The EGR was eliminated when they switched the distributor setup and the ECU for sequential fuel injection.
If you failed for NOX, I would make sure you have a fesh tune up, fresh oil change.
Doing the Seafoam treatment first might help since carbon buildup in the combustion chambers can cause high temps in the CC's which can cause high NOX. HTH. If it fails after that, try a new cat.
Re: 1991 montero 3.0L does not have an EGR valve. I think? [Re: justice] #999006 06/03/10 03:31 PM
I thought that changing out my cat was going to have to be an option. Pardon my ignorance, as I haven't owned an older car for a long while. What exactly is the sea foam treatment. I hope I can get it in a can and not an actual coast line. Although, on some coast lines, now, I can probably get an oil change. Please enlighten me on the sea foam treatment. Thanks for the info. Very helpful!
I am a walrus.
Re: 1991 montero 3.0L does not have an EGR valve. I think? [Re: canyonrc28] #999007 06/03/10 05:24 PM
Another person in Phoenix! Hot [email]D@mn![/email] Welcome.
SeaFoam is an additive you can buy at auto parts stores. Comes in a red and white metal can. Get two cans.
Put one entire can in a tank of fuel. Drive that tank of fuel down before refilling.
At the same time, put half of another can in the oil. When the tank of gas is about to be refilled, change the oil.
With the remaining half can, and this is the fun part, and you do this at the same time you add the other cans in, too, you need to pull off the vacuum line that feeds the brake booster. Tape a skinny line on to the end of that line to make a 12" long line that is leading to the intake of the engine. Start the engine and have an assistant help keep the engine running while you do this (because it will want to stall). Don't rev the heck out of it, but keep it running while you slowly have the engine inhale bits of the SeaFoam from the can into that line. Do a little at a time to avoid stalling the engine until it's all inhaled, then shut the engine off and let it sit for about an hour.
When you are letting it sit, take off the skinny line and reconnect the brake booster. Here's the fun part, but your neighbors will not like this. When you restart the engine, find the fastest way out of your neighborhood and on to the closest freeway. There will be a HUGE cloud of smoke coming out of the back, and I mean HUGE. Proceed to drive the heck out of the car for a few miles. Rev it to redline, or close, before letting it shift. It will smoke for a few miles and gradually diminish. Return home when you think your neighbors may have gone about their business and won't be waiting with the EPA.
This cleans out the intake system and combustion chambers. The SeaFoam in the oil will help clean out the lower part of the engine, and the stuff in the gas tank helps with the fuel delivery system. Total cost is about $20, plus the gas you burn and the oil change you do after the 200-odd miles.
Re: 1991 montero 3.0L does not have an EGR valve. I think? [Re: JohnnyBfromPeoria] #999008 06/03/10 06:33 PM
justice Offline
It helps if you do it at night <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 1991 montero 3.0L does not have an EGR valve. I think? [Re: canyonrc28] #999009 06/04/10 12:33 AM
KrzyDav Offline
I still have my original cat , it's a federal emmissions and it still passes CA emmissions test.
I think alot of cats must get replaceced unnecessaraly
dave h.
Re: 1991 montero 3.0L does not have an EGR valve. I think? [Re: JohnnyBfromPeoria] #999010 06/04/10 12:59 AM
Wow! I am going to have to go to a rural area to do this. Ironic that this will help pass emissions yet cause so much emissions. Thanks for the advise. <img src="/forums/images/graemlins/cheers.gif" alt="" />
I am a walrus.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6351 MB (Peak: 0.7404 MB) Data Comp: Off Server Time: 2026-06-09 21:55:38 UTC
