3.5L 24v - Need to remove intake to replace lash adjusters? #999241 06/05/10 07:46 PM
scottiesharpe Offline OP
Today I had planned to replace all 24 lash adjusters. Many of them are noisy below 3000 RPM and no amount of oil changes, high detergent or not, has improved them. Napa had the upgraded adjusters available with the 3mm oil hole. Paid about $250 for all 24. Gulp!
It appears as though I need to remove the upper and lower intake plenum to remove the valve covers so that I can replace the lash adjusters.
Now I am wondering if I should bite the bullet and replace my JB-welded lower plenum with a new Mits part. I am not going to get rid of this rig anytme soon, so it is attractive to me to restore the original functionality of the intake plenum butterflys.
Do I need to remove the intake to remove the valve covers, or have any of you squeezed them out with taking everything apart?
Thanks!
Scottie Sharpe
Sunny San Jose CA
Webmaser for BMW TURBOS! Forum
http://bmwturbos.scottiesharpe.com
1995 Montero SR
Re: 3.5L 24v - Need to remove intake to replace lash adjusters? [Re: scottiesharpe] #999242 06/05/10 09:02 PM
mxmikie Offline
you just need to remove the upper intake manifold i have a plugged center section (no butterflys) and i rent the tool to compress the springs you will also have to remove the camshafts so might as well replace the cam seals while you are doing the job make sure that you plug all the oil passages with rags so you dont drop a keeper down into the engine
Re: 3.5L 24v - Need to remove intake to replace lash adjusters? [Re: mxmikie] #999243 06/06/10 01:04 AM
sewerrat Offline
I have had some luck replacing the lifters with the cams in place. Just need to have the cam lobe "up", compress the valve, pop the rocker arm off. Swap the lifter and reverse. It's "just that easy". <img src="/forums/images/graemlins/lol.gif" alt="" />
Except for the stubborn ones. <img src="/forums/images/graemlins/evil.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/rodent.gif" alt="" />
95 Montero SR 3.5 sitting on the sidelines.
96 Montero LS Daily driver.
88 Audi 90 Quattro marking it's territory.
69 Bronco built but uncut garage queen.
TANSTAAFL
Re: 3.5L 24v - Need to remove intake to replace lash adjusters? [Re: sewerrat] #999244 06/06/10 05:44 AM
Thanks guys. I imagine I'll need to rent the valve spring compressor tool to do this?
Scottie Sharpe
Sunny San Jose CA
1995 Montero SR
Re: 3.5L 24v - Need to remove intake to replace lash adjusters? [Re: scottiesharpe] #999245 06/06/10 05:55 AM
justice Offline
EDIT
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6090 MB (Peak: 0.6744 MB) Data Comp: Off Server Time: 2026-05-26 04:55:29 UTC
