Re: Help me identify this green switch on the dash of my 84 montero sport: [Re: monty84] #999414 06/08/10 04:04 PM
LandRaider Offline
MAYBE.... Someone took an OEM mitsu switch, and broke the guts out of it, and mounted some aftermarket switch inside the orig mitsu switch? That way it would be super clean?
Re: Help me identify this green switch on the dash of my 84 montero sport: [Re: monty84] #999415 06/08/10 04:36 PM
8
89IsMine Offline
I have consulted the manual to no avail.
There is no section for dash/interior, only electronics and i have checked every page in elect. section with no explanation of any of the switches. The reason I thought it was stock is that the previous owners were an older couple who just used this on weekend family trips and when I asked them about it they had no idea.
Whoops, missed that first quote earlier <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
I agree with the opinions above -- time to pop the switch out of the dash and trace the wires.
Eric W.
Re: Help me identify this green switch on the dash of my 84 montero sport: [Re: LandRaider] #999416 06/08/10 05:08 PM
monty84 Offline OP
Yep I'll trace some wires, however I'm still confused about what switch was originally in that location, since the gate lock is manual.. Who else has an 84??!
'84 Monty SWB, 2.6 Manual, rear LSD, bOuNcY, cranked T Bars, 33x12.5 M/T's
Re: Help me identify this green switch on the dash of my 84 montero sport: [Re: LandRaider] #999417 06/08/10 06:46 PM
N
NickR Offline
That what it looks like to me, they took a Mitsu OEM blank, used a dremel to cut the hole for the switch. Regarding what switch goes there, it's possible there was just a blank there from the factory. Depending on the model you have, not all the dash switch area have switches in them.
1987 Dodge Raider, stick on 33", 2.5" BL, Con-ferr roof rack, Hella driving lights & pencil beam lights.
Stuff collecting dust in the garage
SR Axle
LSD 3rd member
Early Gen 1 Bouncy seat
Early Gen 1 two piece rear bumper
2 sets of SWB Gen I rear seat-belts.
Set of Aisin Hubs.
Re: Help me identify this green switch on the dash of my 84 montero sport: [Re: monty84] #999418 06/08/10 10:03 PM
Counting you, I think there are three that have come through these ranks.
Also, we all have blanks that are simply covererd and would have held switches for options the US never saw.
Re: Help me identify this green switch on the dash of my 84 montero sport: [Re: MontyMcV] #999419 06/08/10 11:01 PM
That was a special switch only used for the very rare super encabulator option. Do not throw the switch on wet pavement, as the truck may behave differently than you are used to, thus endangering life and property. Only use super encabulator mode as described in the owner's manual supplement...
Betcha there used to be fawg laghts on it...
Re: Help me identify this green switch on the dash of my 84 montero sport: [Re: MontyMcV] #999420 06/08/10 11:06 PM
8
89IsMine Offline
OK, my curiosity was piqued, so I downloaded the '84 FSM and did some looking myself and I came across the description of the rear heater, which has a single push button switch which combines heater fan switch and warm water flow control operation. The manual describes it as ON-OFF operation. The only illustration I could find was on page 24-35 of the manual.
Is it possible this might be your mystery switch? After all, a system that has a secret box and secret box packing ought to have a mystery switch, right? <img src="/forums/images/graemlins/wink.gif" alt="" />
Eric W.
Re: Help me identify this green switch on the dash of my 84 montero sport: [Re: RECON45] #999421 06/10/10 07:10 AM
93montero_sr Offline
That is a nice looking and fit aftermerket switch. I bet its been on their awhile, you probably could not find those nice fitting switches today.
I have a switch just like that it operates my aftermarket lights on my rear bumper. That switch used to go to something thats no longer on the vehicle.
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: Help me identify this green switch on the dash of my 84 montero sport: [Re: 93montero_sr] #999422 06/10/10 07:23 AM
monty84 Offline OP
thanks for all the responses guys, the switch lights up when you activate it and the headlights are on, so I'm pretty sure it used to go to some lights. I guess I'm all wired up if I wanted to get some hella's <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6373 MB (Peak: 0.7581 MB) Data Comp: Off Server Time: 2026-10-27 00:45:29 UTC
