Deep Cycle Battery Question #999545 06/09/10 10:09 PM
Greg B Offline OP
Hi all,
I need to replace the battery in my 90, and have question. Is running a deep cycle battery OK for day to day use, or should I get a standard battery?
Thanks,
Greg B
94 SR Sold
90 Green 4DR LS, Sold to Scottys90
Re: Deep Cycle Battery Question [Re: Greg B] #999546 06/09/10 11:30 PM
plh Offline
Standard battery
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Deep Cycle Battery Question [Re: Greg B] #999547 06/10/10 12:22 AM
hazy_daze Offline
In the heat where you are, I'd likely get a yellow top Optima. It'll stand up to alot of abuse and still be able to handle deep cycle-like discharges.
But, it really depends on what you're expecting from it. What's your typical usage like?
Re: Deep Cycle Battery Question [Re: hazy_daze] #999548 06/10/10 02:47 AM
plh Offline
a deep cycle isn't so good for running starters or winches. Great for things with constant draw like lights.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Deep Cycle Battery Question [Re: plh] #999549 06/10/10 03:08 AM
Deep cycle will survive many full discharge event. Std will not, but has much higher cranking amps. Deep cycle is for trolling motors on boats.
Re: Deep Cycle Battery Question [Re: fasteddy] #999550 06/10/10 03:21 AM
plh Offline
Yes, Standard Automotive type "Starting" batteries have high cranking amp capacity. True "Deep Cycle" batteries are made for long slow discharges and recharges. It will not hurt to use a deep discharge as a starting battery, it will however need to be physically larger to deliver a similar cranking amp capacity as a "Starting" battery. Typically Deep Cycle batteries are more expensive than starting batteries.
More than you probably care to know can be found here:
Wind Sun
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Deep Cycle Battery Question [Re: Greg B] #999551 06/10/10 04:04 AM
redbull Offline
The Optima yellow top is actually (they claim) a combination deep cycle/starting battery.
http://www.optimabatteries.com/optima_products/yellowtop/index.php
Still, I'd get a regular battery for regular starting duty.
Re: Deep Cycle Battery Question [Re: redbull] #999552 06/10/10 04:31 AM
Greg B Offline OP
Thanks for all the good info. I donÆt have any heavy electrical loads on my truck, so I guess I will get a standard battery. The deep cycle was only 6 bucks more, and I was looking to get the most bang for the buck. Seems like batteries only last about three years for me.
Greg B
94 SR Sold
Re: Deep Cycle Battery Question [Re: Greg B] #999553 06/10/10 09:19 AM
Greg, get something with a full 3-year replacement warranty for use here in Phoenix. You'll need it, as they never make it that long with the heat.
Re: Deep Cycle Battery Question [Re: JohnnyBfromPeoria] #999554 06/11/10 12:19 AM
U
undertheinfluence Offline
I've typically found good pricing on batteries of all types at Sams Club, however In September of last year I found Batteries Plus to have a killer deals on Optima batteries. I am not sure if this is still the case but I would check it out...
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6385 MB (Peak: 0.7623 MB) Data Comp: Off Server Time: 2026-11-02 12:33:22 UTC
