drivers side seat belt replacement? #999772 06/13/10 11:18 AM
menotthat Offline OP
Has anyone replaced their seat belt themselves?
Mine is getting frayed. I got a new one from kia and was wondering if i should use blue or red locktite on the bolts?
97 sportage, mostly stock apart from king springs front and rear, monroe shocks, k&n filter, pioneer mp3 cd, rampage 2x 10"subs and rampage amp.
Re: drivers side seat belt replacement? [Re: menotthat] #999773 06/13/10 02:36 PM
Everet Offline
Personally, I would use Blue. Make sure that you torque them properly. Check them in 6 months then again in another 6 months to make sure they are staying tight. Never had an experience where a bolt backed out using blue.
Everet
Re: drivers side seat belt replacement? [Re: Everet] #999774 06/15/10 03:59 AM
londart Offline
i replaced mine when i swapped my interior,very easily done...just remove any visible screws and bolts and then carefully pry trim up so as not to break any tabs off...everet is right in that blue does not usually back off but i believe they originally had red, and seat belt bolts arent something you pull off on a regular basis so red would be fine as well,just harder to get off if ever needed <img src="/forums/images/graemlins/cheers.gif" alt="" />
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
Re: drivers side seat belt replacement? [Re: Everet] #999775 06/17/10 01:18 PM
thanks guys. i will use the blue.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6006 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-07-17 05:22:01 UTC
