ugggg! no drive #1000192 06/15/10 08:01 PM
runningbird Offline OP
well I was get ready to put the raider on a trailer and head up north. the starter has been sounding a little loud and a vibration some place from 2000 - 2500 rpm. always been like this but getting a little worse. anyway went to start it and heard a bang, started up and the vibration was worse. turned it off looked around and all looked ok. stater was tight so tried to start it again and did not want to start but did on the 2nd try. vibration a little worse put it in gear and thing got loud put it in park and things got quiet. back in gear and nothing. no forward or reverse. linkage is ok. and when I start it now the vibration is gone for the most part. wonder if I trashed the fly wheele/ torque converter?
I'm going to look at the manual now and the jack it up and pull the inspection cover on the bell housing... if I have to pull the trans/and transfer case do you all pull the motor or just the trans.
any thoughts would be great.
Mark
87 raider starion motor in, looking for an auto trans.
Re: ugggg! no drive [Re: runningbird] #1000193 06/15/10 08:17 PM
zarktheshark Offline
could be the flex plate bolts backed out. does it do anything in reverse?
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: ugggg! no drive [Re: zarktheshark] #1000194 06/15/10 08:24 PM
nothing in any gear or range
Re: ugggg! no drive [Re: runningbird] #1000195 06/15/10 08:53 PM
when you tried to start and it did not want to, what exactly happened? did the starter turn but not the engine?
'15 Subaru XV
'03 BMW i325
Re: ugggg! no drive [Re: zarktheshark] #1000196 06/15/10 09:25 PM
took the inspection cover off and the flywheel is loose,as is the adapter between the crank and flywheel. I will probably pull the motor and check it out.
any one have a flywheel for sale. or a stock exhaust manifold for a 2.6? I don't like the power band with the header.
Re: ugggg! no drive [Re: runningbird] #1000197 06/16/10 01:47 PM
this is what I found, the flywheel bolts have backed out our broke off, the center of the crank appears to have a center bushing or something like it and it sticks out about a 1/16th of an inch. I'm suprised it lasted this long.
I'll be taking the whole motor to a machine shop to have them look at the crank and see if it can be salvaged.
Re: ugggg! no drive [Re: runningbird] #1000198 06/16/10 04:38 PM
Ouch. If you find a thin washer\spacer that goes between the flexplate and the crank, keep it as they are hard to come by and are absolutely needed.
'15 Subaru XV
'03 BMW i325
Re: ugggg! no drive [Re: zarktheshark] #1000199 06/16/10 04:46 PM
thin washer? I do have the spacer and it is about 1/2" thick. is this it?
Re: ugggg! no drive [Re: runningbird] #1000200 06/17/10 06:15 AM
this is the part number for the thin plate
MD952195
this is for the thicker(crank shaft side)
MD020982 Crank shaft adapter
I can't find any pics.
'15 Subaru XV
'03 BMW i325
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6310 MB (Peak: 0.7344 MB) Data Comp: Off Server Time: 2026-11-03 13:34:11 UTC
