Toyota wheels and Magnaflow installed, pics and vid #1000667 06/20/10 12:02 AM
BoiseMontero Offline OP
I have always liked these Toyota wheels and found a good deal, now I just need the 5th one.
before I feel it was too much black
[img]http://[image]http://i367.photobucket.com/albums/oo112/jon98tj/Montero/Toyota%20wheels/2010-06-04_00001.jpg[/img][/image]
and after
[img]http://[image]http://i367.photobucket.com/albums/oo112/jon98tj/Montero/Toyota%20wheels/2010-06-18_00005.jpg[/img][/image]
and here's the new Magnaflow exhaust, don't mind the door squeak lol
http://www.youtube.com/watch?v=OmLNzeZ4_OM
Re: Toyota wheels and Magnaflow installed, pics and vid [Re: BoiseMontero] #1000668 06/20/10 05:51 AM
hazy_daze Offline
Those look really good. I may have to find me a set. Sounds good too. Is yours a manual? If so, it kinda sounds like some bearing noise. Maybe the pilot bearing or input shaft bearing. May just be background noise too...
Re: Toyota wheels and Magnaflow installed, pics and vid [Re: BoiseMontero] #1000669 06/20/10 03:51 PM
socal1200r Offline
Nice find, there's another Monty on the board that has those same wheels, looks good. Kinda dresses it up a little bit. What's the specs on those wheels (diam and width), and what size tires are you running?
1989 Monty SWB, 2.6L w/MT, 15" alloys, 265/75 Dunlop Radial rovers, rear air shocks, Weber 32/36, SQ oil cooler, (SOLD Oct 2012)
Southeast VA, USA
Re: Toyota wheels and Magnaflow installed, pics and vid [Re: BoiseMontero] #1000670 06/20/10 05:00 PM
PCMONT Offline
It does look good. Here's a little trick to make you rig look a little newer and get good contrast against the aluminum wheels. Go buy a couple cans of spray on bedliner. Paint the inside of your fender wells. It's quick and easy. I did mine and love the results. <img src="/forums/images/graemlins/kewl.gif" alt="" />
91 LWB 3.0 w/300K. Nothing fancy yet...still getting the quirks out and cosmetic fixes.
Re: Toyota wheels and Magnaflow installed, pics and vid [Re: hazy_daze] #1000671 06/21/10 12:16 AM
It is a manual, what's pilot or input shaft bearing? Clutch stuff? Thanks for the info.
1989 SWB V6 5 speed 230K
Re: Toyota wheels and Magnaflow installed, pics and vid [Re: socal1200r] #1000672 06/21/10 12:21 AM
Thanks, They are 15x7 with 4 3/8" of backspace, the wheel says 8 offset. There are other ones like this that say '10' offset, not sure what the backspace is on those. I measured these and came up with the 4 3/8" so it may be plus or minus a few 8ths. They weigh around 16 pounds each, but are a flat seat so they take a special lug nut. You can't use the tapered seat lug nuts that our factory wheels use. I'm still looking for center caps and a 5th wheel for my spare. The Toyota wheel part number (as far as I can tell) is 69305. The lug nuts are 611-117 M12-1.5 x21mm and can be found on rockauto for a few dollars each.
Re: Toyota wheels and Magnaflow installed, pics and vid [Re: BoiseMontero] #1000673 06/21/10 07:03 AM
Both would be located between the output of the engine and the input to the transmission, or thereabouts. Does the noise go away when you depress the clutch pedal? Usually, it'll sound like a light rattle that will kind of wind down after you push in the pedal. They are parts that should be replaced when you do a clutch job.
Re: Toyota wheels and Magnaflow installed, pics and vid [Re: JohnnyBfromPeoria] #1000674 06/21/10 01:28 PM
haztoys Offline
SSHhhh... Don't tell everyone about these wheels ..LOL.. You'll make them hard to get .. Ive been running them on half the Mitsu's in the famliy for some time now.. Have run them on the Rally truck for tarmac runs .. Have had good luck with them ..And "I" like the way they look ..
I "think" the 8's are truck and the 10's are Toyota Land cruiser...In my travels I've never come across 10's.. Just a guess on that..
Whats the tire size...And how do you like them...???
Have a good day
David
Hazardous Toys inc
Re: Toyota wheels and Magnaflow installed, pics and vid [Re: haztoys] #1000675 06/22/10 03:26 AM
There is a slight different sound when my clutch is in, but no rattle.
Sorry I forgot to answer the tire question earlier, they are stock size 235's. The tires are Mud Kings, I'm told are made by BFG.
Re: Toyota wheels and Magnaflow installed, pics and vid [Re: haztoys] #1000676 06/22/10 08:39 PM
monty84 Offline
I have the 15x7 landcruiser alloys on my rig, and the stock lugnuts fit just fine.
'84 Monty SWB, 2.6 Manual, rear LSD, bOuNcY, cranked T Bars, 33x12.5 M/T's
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.003s) Memory: 0.6392 MB (Peak: 0.7645 MB) Data Comp: Off Server Time: 2026-05-30 01:21:37 UTC
