My vehicle is a 1995 Toyota T-100 Extra-Cab 4WD 3.4L Automatic.
Both my CV axle boots are shot and have been so for a while since this and every forum says to replace instead of repair so I just kept driving on them for the last year till I found time to replace.
Per everyone's recommendation at this forum (if you decide not to go OEM) I ordered the Cardone Select 1/2 shaft which is an all new manufactured axle (unlike their older A1 Cardone 1/2 shaft which is a rebuilt and known to have quality issues).
Also per this forums recommendations I ordered from RockAuto (due to their low prices).
Instead of receiving two Cardone select 1/2 shafts I received only one, the other being an "INTERPARTS" 1/2 shaft (doing Google it turns out they are a chinese outfit with three factories that makes knockoff vehicle replacement parts).
http://interparts.com/ I know nothing about this outfit (INTERPARTS) but if they are recommended by folks here then I will just keep it even though the two 1/2 shafts will look a bit different.
Appearances wise the Interparts 1/2 shaft looks to have higher quality machining of the metal, like the splines are cleaner. It is gun blued instead of the poor quality phosphate finish of the Cardone (does not really matter as I will paint since Cardone are known to rust quickly where axle is exposed). The Interparts shaft came in a non-descript brown box with no markings and no instructions or warranty card. The rubber boot on the Interparts does not seem to flex as cleanly as the Cardone. They both seem to turn/flex with the same stiffness and roughness
Unfortunately the most import part (internals/bearings) is not accessible to check on where the quality really counts most.
QUESTIONS:
[color:"red"]
QUESTIONS: [/color]
[color:"blue"]
Anyone ever heard of these folks before and seen any recommendations for them?
How do they compare to the Cardone select 1/2 shaft (which is recommended by many folks at this forum)?
Anyone have first hand experience using these shafts?
If you had this situation would you go through the hassle of a return to get the matched set of Cardone 1/2 axles?
[/color]
On another note.......
......Both companies shipped these shafts loose without packing in their boxes. Not a problem for the tough metal axle, but the poor dust shields which they both mounted on the shaft got smashed up and is worthless. Anyone know where to get new ones? I will try Rock Auto, but they do not list them, and will probably want me to ship them back, and the replacement ones will probably be smashed also since I don't expect it to be packaged any differently.
![[Linked Image]](http://www.hunt101.com/data/500/medium/4-DSC02047.JPG)
