Finished paint job #1001227 06/26/10 11:13 PM
SandRaider Offline OP
I finished painting my Raider today. I think it looks great. Paint is desert tan military CARC paint. I purposely didn't fix any dents or holes from body rot, but I did sand all the rust to bare metal so it won't bubble up. I'm gonna end up dentin and scratchin it anyway, but I have a bunch of paint left over and it's flat so i can touch it up anytime. And yes, those are hardbor freight sale ads used to mask off windows and such. I grabbed about 6in thick worth of ads when I bought my $15 paint gun, saved me from buying newspapers. I can offically call it the SandRaider, and not that factory champagne color.
Eric
89 Raider V6, 35s, 5sp, welded rear, 8k winch
89 Raider 2.6 going on 84 4runner frame
Re: Finished paint job [Re: SandRaider] #1001228 06/26/10 11:37 PM
BoiseMontero Offline
I love it! Where did you get the tan? Is the black a bedliner?
1989 SWB V6 5 speed 230K
Re: Finished paint job [Re: BoiseMontero] #1001229 06/26/10 11:55 PM
LandRaider Offline
CARC paint is NASTY crap, but it is durable as HELL!!!!!
Looks GREAT!!!! VERY similar to my big rig.
Re: Finished paint job [Re: LandRaider] #1001230 06/26/10 11:59 PM
runningbird Offline
looks pretty darn good! can you tell me what size tires and rims you have, body lift spring lift?
thanks
Mark
87 raider starion motor in, looking for an auto trans.
Re: Finished paint job [Re: runningbird] #1001231 06/27/10 01:30 AM
themacway Offline
eric, very nice job. looks like you got an even top coat out of that nasty (to use) stuff. did you get the sherwin williams #686 tan? did you use an hvlp setup or regular gun? just curious, as i've been wanting to try that particular paint on an old raider that's here in town needing a good finish. i know the carc is somewhat of a pain to use for a polyurethane paint, but i've heard the new type 2 is much more manageable. it's at the store here for $69 a gallon, and since it's a low voc paint, i'm really looking at it hard for its durability.
great job! it'll be lotsa fun, and you'll get a lot of questions from folks on the paint.
jack b :-) in midland, tx
'89 raider v-6, blue w/blue-grey, auto, superwinch hubs, a/c, cruise/tilt, bouncy, big wheels/tires/suspension and kewl ol' school trailmaster motorsport grill guard and body damage! now with a yammie xt600e duallie mounted across the rear.
Re: Finished paint job [Re: themacway] #1001232 06/27/10 02:22 AM
I got the paint from www.milspray.com. It's a "classic military vehicle restoration paint". It is a single stage water dispersable polyurethane CARC paint, low voc, which is why I bought it, though it was a bit pricey, and 2qts can cover an entire 2dr, so I have about 2qts left out of a gallon, which I'll probably need to touch up spots after I scratch/dent it. It was extremely easy to spray, right out of the can, no thinning, mixing, etc. I used a regular gun I picked up at harbor freight for $15, though they do reccommend an hvlp gun, but it worked fine without, though it is 2 coats of paint on top of 2 coats of primer. The black is just rattle can semi-flat black. I didn't have any bedliner left after spraying the entire interior. For that I used dupicolor bedliner kit (regular not kevlar) and sprayed it on using a paint sprayer for spraying popcorn textured ceilings, which I borrowed but you can get them at harbor freight for $25. It worked great because it gave the texture with it, didn't clog the nozzle once, though it obviously can only spray textured. For the guy that asked, my Raider has a 3" body lift, from roger brown, stock springs, tbars cranked (if you can't tell by my camber), 35x12.5 dunlop mudrovers and one mud king on pro comp rockcrawler 15x8 steel wheels w/ 3.75" backspacing, no rub
Eric
Re: Finished paint job [Re: SandRaider] #1001233 06/27/10 02:28 AM
LandRaider Offline
I always got mine from the DRMO hazmat dumpster. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> I've got about 4 gallons left of Khaki.
You ARE NOT!!! going to spray this stuff, and just rolling it on will almost kill you. I painted a deuce and a half with a bucket truck body on it, and it almost killed me. I had to wear a breather it was so bad. That was with a brush!
Re: Finished paint job [Re: SandRaider] #1001234 06/27/10 03:50 AM
Turned out great. Love the "all business look" the paint gives it.
Re: Finished paint job [Re: LandRaider] #1001235 06/27/10 06:18 AM
StockRaider Offline
my friend paints CARC 5 days a week. Has to get blood tested every couple months too. He absolutely curses the stuff. He has to spray it on too. Runs like piss he tells me.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Finished paint job [Re: StockRaider] #1001236 06/29/10 01:24 PM
RECON45 Offline
I was thinking about painting my montero military tan. looks good, but I might go with the green so I am not a copy cat. <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6390 MB (Peak: 0.7651 MB) Data Comp: Off Server Time: 2026-07-09 17:40:50 UTC
