Page 3 of 4 1 2 3 4
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: fasteddy] #1001292 06/28/10 04:00 AM
FrankR Offline
How 'bout we use the rabbit droppings to fuel a burner in back. Heat from the burner can be routed upward through the roof, but intercepted by a wheel that produces enough current to load a coil that is connected to a spark plug mounted on the methane gas nozzle. Every time a female rabbit drops a new bunny, the young one falls on a switch that collapses the coil field and the spark plug ignites an explosion from the rear of the truck.
We could call this powerful system the Flame Associated Kinetic Energy Fast Ascent Rough Terrain engine....... or....... F.A.K.E.F.A.R.T.
I think it'll become known as a kind of wasted spark ignition. <img src="/forums/images/graemlins/wink.gif" alt="" />
Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: FrankR] #1001293 06/28/10 04:45 AM
toyhooter Offline OP
How did this get about being green and lighting your farts? Its about using more gas and shoving more air up your intake.
ToyHooter
90 LWB Montero
Sliders, Dual Bouncies, K&N, Flowmaster, Rancho Stabalizer, KYB Gas Adjusts,
ARB Compressor Under Hood, ARB Locker Waiting Garage Floor, Spare Tire Bike/CB Ant Mount
"I didn't do it, you didn't see me, you can't prove it."
Bart Simpson
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: toyhooter] #1001294 06/28/10 04:52 AM
Chigger Bates had wasted spark ignition on the Bic mounted on his bong.
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: fasteddy] #1001295 06/28/10 09:22 PM
Bongs? <img src="/forums/images/graemlins/drunk.gif" alt="" />
<img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: toyhooter] #1001296 06/29/10 01:11 AM
redbull Offline
Because someone with a ton of knowledge and experience flat out told you it won't work, then someone explained why it won't work, and you don't listen like most who fall for the "hair dryer in my intake" scam. So, they are entertaining themselves and making fun.
Tell you what, forget all this 12V crap and start Googling Brown Gas. That should keep you busy.
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: redbull] #1001297 06/29/10 01:42 AM
StockRaider Offline
Ive got like 30 120mm PC case fans, would that work if I duct tape them all together on the intake tube? Maybe a shopvac and a power inverter? <img src="/forums/images/graemlins/lol.gif" alt="" /> a poor mans turbo would not be an electric motor, it would be a homefabbed turbo manifold and a junkyard turbo. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: StockRaider] #1001298 06/29/10 04:05 AM
Only if you're careful to wire them correctly.
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: JohnnyBfromPeoria] #1001299 06/29/10 06:50 AM
Kevin C Offline
web page
Might as well use factory mits technology.
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: redbull] #1001300 06/30/10 06:30 AM
[/quote]
Tell you what, forget all this 12V crap and start Googling Brown Gas. That should keep you busy. [/quote]
Brown gas. Yea isn't that a by-product of a lighting your farts and having a gasket leak. Often a side effect of many new Geezer meds........ Yea I get it. I've been told it won't work. By the EX-SPURT no less. Ok Turbo was a bad analogy. But cmon man. "Po Mans Turbo" That was agitation genius. I was just thinking about getting a little extra torque at low speed without having to move to a state that overlooks swapping out your Federal/factory engine. Like I said I am still going to fxxk with this and if it even slightly works I will book an hour on a Dyno and post it.
<img src="/forums/images/graemlins/nana.gif" alt="" />
ToyHooter
90 LWB Montero
Bart Simpson
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: toyhooter] #1001301 06/30/10 07:01 AM
StockRaider Offline
So you're wasting your money just to snub some very knowledgeable people? Sounds like a bit of the "butthurt" is going on in here. <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E
1983 Honda XL600R
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.007s) Memory: 0.6471 MB (Peak: 0.7718 MB) Data Comp: Off Server Time: 2026-11-02 08:29:39 UTC
