Page 4 of 4 1 2 3 4
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: toyhooter] #1001302 06/30/10 07:07 AM
I was just thinking about getting a little extra torque at low speed without having to move to a state that overlooks swapping out your Federal/factory engine.
State allows you to swap in a different engine so long as it's from a newer vehicle and not an older one. Many with the 2.6 have swapped in the Starquest turbo setup. Others have swapped in a 4.3L v6 chevy.
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: off-roader] #1001303 06/30/10 07:12 AM
Just let the guy try it. Can't hurt...us. Report back on your progress.
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: JohnnyBfromPeoria] #1001304 06/30/10 03:35 PM
RECON45 Offline
I thought about something similar to this that I was going to hook up to variable switch attached to the throtle cable so as you give it more gas it would force more air in. Never went to far with it. it was suppose to be my Senior Project in Engineering but I switch majors and never finished it. my professors like it. maybe you get something to work. The other thing I was working with in this project was smooth air ways to the engine to have less turbid air.
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: RECON45] #1001305 06/30/10 11:26 PM
Why not just take a page from old bomber tech and run the exhaust thru a power turbine hooked either to the driveline direct or to a genset then to an electric hybrid motor, a la the old turbo compound piston/turbine engines...
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: fasteddy] #1001306 07/02/10 07:45 AM
L
Lee N Offline
Haven't posted in a while but thought I'd jump in. This is probably not cheap, but it is a true well engineered 12V supercharger - VTES system. I believe VW was experimenting with some sort of compound forced induction system that used a 12V powered supercharger.
BTW, this company also has an exhaust powered generator.
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: Lee N] #1001307 07/03/10 01:00 AM
hazy_daze Offline
Pretty neato stuff...
Re: Po Mans Turbo AKA Electric Motor Intake Boost Assist [Re: hazy_daze] #1001308 07/03/10 08:41 PM
LandRaider Offline
Is this
Over?
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.6278 MB (Peak: 0.7185 MB) Data Comp: Off Server Time: 2026-07-17 02:16:37 UTC
