Fuel injection pump #1002636 07/09/10 10:15 PM
sasquatch Offline OP
Any body had a leak from the injection pump?
Mine is leaking from the the engine side (right side the most)
I have tried to retorque the allen bolt but no success.
I will check with Rocky Mountain Imports for the price of a new pump...
I thought to seal it with some metal paste all around, that would take care of the leak!!!
Just talked to RMI and he said should not have any surprise if I take the governer top part of the pump. No hidden spring and just reseal it.
Anybody took that part off before?
Pat
Pat
Re: Fuel injection pump [Re: sasquatch] #1002637 07/10/10 05:47 AM
redbull Offline
Never had mine apart, but I remember torquemonster saying the pump is very similar to an old VW unit. You might want to check with a VW shop that has diesel experience.
Re: Fuel injection pump [Re: redbull] #1002638 07/10/10 08:17 PM
torquemonster Offline
Our Zexel pump is a knockoff of the Bosch pump used on 80's VW diesels, older Dodge cummins used a similar pump. its very common.
I have a leak in the same place as your describing but have also been scared to pull it apart. my next timing belt change it coming up this winter so I think that is the time I will pull my pump out and see what I can find. if you get yours done before me lets keep in touch!! I'd like to know what I'm getting myself into.
Re: Fuel injection pump [Re: torquemonster] #1002639 07/11/10 12:33 AM
I will let you know.
I will do some searching around before I take it apart to make sure...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6008 MB (Peak: 0.6569 MB) Data Comp: Off Server Time: 2026-07-09 18:33:25 UTC
