code 22 and stalling starts but stalls #1002764 07/11/10 10:31 PM
G
graeaglecrawler Offline OP
I've got a '91 v-6 it stalls sometimes and while it was idling I wiggled the harness connector on the distributor and it stalled. I have 228k on the motor and 30k on distributor. I read a code 22 from the test harness. Anybody dealt with this?
'91 montero a/t cranked t-bars 31x10.5x15 212k
'90 toyota extra cab 320k v6 5 speed 31's 4x4
'99 expedition 17" alloys v-8 207k 4x4
'88 BMW 325iX 247k AWD
'59 Willys Jeep Koenig PTO winch and hardtop 28k
Re: code 22 and stalling starts but stalls [Re: graeaglecrawler] #1002765 07/11/10 10:59 PM
FrankR Offline
Code 22 is the Crank Angle Sensor - it's located in the distributor. It may be a loose connection or a bad CAS.
Frank
Re: code 22 and stalling starts but stalls [Re: FrankR] #1002766 07/11/10 11:18 PM
G
Can this be taken apart in the distributor? Has any one found a distributor for under $200 anywhere? Thanks
Re: code 22 and stalling starts but stalls [Re: graeaglecrawler] #1002767 07/12/10 01:48 AM
FrankR Offline
I haven't done it, but I would imagine it can be disassembled fairly easily. Try a junkyard for a replacement distributor - it'll probably cost less than a new CAS.... but get a warranty so you can return it if it's no good.
Frank
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6035 MB (Peak: 0.6588 MB) Data Comp: Off Server Time: 2026-10-21 17:31:22 UTC
