1991 Montero RS Air Lift Suspension #1002922 07/13/10 05:21 AM
canyonrc28 Offline OP
Has anyone tried the Air Lift Suspension. I want to put bigger tires on but I am worried about rubbing. I thought this might be a good way to get more clearance. Any pro's/cons?
I am a walrus.
Re: 1991 Montero RS Air Lift Suspension [Re: canyonrc28] #1002923 07/13/10 06:05 AM
Stock will handle 32s with minor trimming to the front bumper end caps.
How big r u planning to go?
As for an airlift, i prefer a pair of gen II coils over the air lift setup unless your going bigger than 33's...
Re: 1991 Montero RS Air Lift Suspension [Re: off-roader] #1002924 07/13/10 06:50 AM
33's would be nice but that's where the lift comes in. 32's would be good if I didn't have to do much.
I am a walrus.
Re: 1991 Montero RS Air Lift Suspension [Re: canyonrc28] #1002925 07/13/10 07:09 AM
Canyon. if you want, I'll help you install a body lift. We can do it in a couple of hours and the total cost is about $125. You'd be able to fit 33's no problem then.
Re: 1991 Montero RS Air Lift Suspension [Re: JohnnyBfromPeoria] #1002926 07/13/10 07:29 AM
that would be great Johnny B. I am just a few pay checks away and I'll be able to do it. Buy the 33's, that is. Also, I am replacing the valve cover gasket. By the way, after rotor, pad and bearing replacement, the squeak as survived. it almost deserves to be there. Almost.
I am a walrus.
Re: 1991 Montero RS Air Lift Suspension [Re: canyonrc28] #1002927 07/13/10 07:49 AM
Did you check your sway bar bushings?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6109 MB (Peak: 0.6813 MB) Data Comp: Off Server Time: 2026-06-07 04:49:32 UTC
