undercarriage skid plate fabrication advice #1003034 07/13/10 04:38 PM
Inyo_man Offline OP
I'm planning on fabricating a skid plate for the transmission/transfer case area under my Gen III. I haven't been able to find any aftermarket support for this except through some businesses in Australia.
I'd like to know if anyone has a suggested thickness for the overall plate and if you'd recommend placing stiffing "ridges" on it as well. The plan is to use the existing cross-members for attachment points.
Thanks
'02 Montero: OME suspension, ARB front bumper, homemade skid plates & spare tire Blitz can mount, extended diff. breather, K&N air filter, Optima Yellow Top, BajaRack, IPF lights, Goodyear Duratrac 265/75/16's, RUD 4x4 Grip chains
Re: undercarriage skid plate fabrication advice [Re: Inyo_man] #1003035 07/13/10 04:48 PM
hazy_daze Offline
Thickness required depends on your usage and expectations. Most folks won't need any more than 3/16", good for general underbrush and some light rocks. Not good for heavy rocks or resting the entire weight of the truck on. If you are seriously going to use them, I'd say 1/4"-3/8" would be sufficient. 1/2" if you want to get crazy...
The designs I've been working on use some 3/16" for some parts, all the way to 1/2" for real crucial areas. The trouble is making it modular enough to facilitate trail repairs, yet solid enough to make a difference...
Re: undercarriage skid plate fabrication advice [Re: hazy_daze] #1003036 07/13/10 05:07 PM
Inyo_man Offline OP
I don't do any serious rock-crawling, but I do frequent trails with some extended rock sections where I've wished I had more undercarriage protection.
Thanks for the suggestions. I like your idea regarding the modular plate with varied thicknesses. I was thinking about 1/4-3/8'' thickness, but if I could use 3/16'' in "less vital" places it will reduce the overall weight a bit...all the better.
When using the 1/4'' or 3/8'' I don't image needed any stiffing ridges...true?
Re: undercarriage skid plate fabrication advice [Re: Inyo_man] #1003037 07/13/10 07:27 PM
hazy_daze Offline
When using the 1/4" or 3/8" I don't imagine it'll need any stiffening ridges...true?
All depends on their span and projected weight carrying. 3/8" should be able to bear the load over a foot or so of span without stiffeners. It'll show the effects, but it'll hold. Draw up your design and post it. Some of the folks here have alot more experience at this than me, so I'm sure they'll chime in...
Re: undercarriage skid plate fabrication advice [Re: Inyo_man] #1003038 07/13/10 07:39 PM
If it helps an illustration for the undercarrage is usually contained in the FSM. I know it's in the gen I fsm anyway. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: undercarriage skid plate fabrication advice [Re: Inyo_man] #1003039 07/14/10 02:16 AM
ES_97Sport Offline
1/4" T6061 aluminum usually does a good job. We were using 5/16" for the front skid plate replacement but that turned out to be a waste of metal. If the un-reinforced square area isn't more than say about 2'x2' 1/4" works fine even for heavy bashing. If you're not planning on slamming the weight of the vehicle on it it will certainly work. You can go to 5/16" or 3/8" for larger square areas but at that point you really need to consider supports and mounting more than the metal thickness.
For what you sound like your doing I'd do 1/4" 6061. It'll save weight. Just my 2 cents.
Re: undercarriage skid plate fabrication advice [Re: ES_97Sport] #1003040 07/14/10 02:28 AM
icysyrup Offline
On mine I didnt go any over 3/16th" anywhere......and that includes the rear. What most people fail to realize in my opinion at least is that skid plates need to flex and deform because if they dont to a certain extent then that "Force" is tranfered somewhere else and that is usually not a good thing.
So in my opinion I wouldnt go above 3/16th" and then use some 1-2" angle in certain spots to reinforce it. I have only reinforced my gas tank skid cause it takes the whole weight of the vehicle. Under the oil pan and transmission i just left is flat and it has held up to LOTS AND LOTS OF ROCKS hitting it. After 4 years I finally needed to replace my oil pan one. Anyhow hope this helps.
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: undercarriage skid plate fabrication advice [Re: icysyrup] #1003041 07/15/10 12:23 AM
Inyo_man Offline OP
Thanks so much for everyone's advice and suggestions!
I'm going to start looking into materials soon...
Icysyrup, did you mount your plate for the trans/transfer case from the cross-member? Did you install mounts for the attachment towards the rear?
Is there any way you might be able to post some pics of your handy work?
Re: undercarriage skid plate fabrication advice [Re: Inyo_man] #1003042 07/15/10 05:38 PM
icysyrup Offline
On the rear skid under the transmission pan I ended up drilling two holes in the rear crossmember and running a long bolt through with big washers to hold it. Has held up fine that way and then in the front of that plate I used the mounting tabs that were there. Here are pics of the front skids that I built. Nothing spectacular but they work great and were cheap out of 3/16" All built to utilize the current mounting points that were already in place.
Re: undercarriage skid plate fabrication advice [Re: icysyrup] #1003043 07/15/10 07:28 PM
Mad_Scientist Offline
Hey Icy,
How did you bend the front skid? Do you have access the a brake? <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6435 MB (Peak: 0.7700 MB) Data Comp: Off Server Time: 2026-07-10 01:00:00 UTC
