California smog test and my 93 Montero #1003136 07/14/10 05:57 PM
strat10pro Offline OP
I have a 93 montero 3.0. Got the dreaded SMOG requirement to register the truck. Got it done a year ago and it passed with flying colors so off I went. Not so fast the SMOG man said, "you failed your NO reading at 15 mph" Passing was 350, my reading was 700.
Went and dumped a can of guarentee pass into my tank and burned through a tank of premium, and put a 1/8 tank back in, checked tire pressure, and drove back in. not so fast the SMOG man said "it helped but you are still reading 500" Took the truck to a SMOG repair facitlity "You need a new O2 sensor, and new spark plug wires" After almost fainting when they said 600 bucks I did both my self. After replacing the O2 sensor and the wires, went back to see the SMOG man. Not so fast the SMOG man said "you are now reading 355" What!? passing is 350. So, I jumped in my Montero and drove around in 1st gear for about 15 min and pulled back into the SMOG mans office. With my poor Monty hotter than its been in awhile, "congradulations, you passed with a 349"
Man, I really hate California sometimes..........
1993 Mitsubishi Montero....No smoke!
Re: California smog test and my 93 Montero [Re: strat10pro] #1003137 07/14/10 06:22 PM
monte Offline
Sounds like a weak cat. I had the same issue with my REDCAR and when the turbo started to blow oil, it killed the cat but I did not realize it and had the hardest time passing smog last year.
I tried EVERY trick in the book almost but the guy said "your cat is probably just bad, go down the street to this place and for $110 he'll put a new one on"
I came back an hr later and it passed with flying colors!! <img src="/forums/images/graemlins/lol.gif" alt="" />
I know.. Cali smog sucks!! <img src="/forums/images/graemlins/nana.gif" alt="" />
1986 SWB Turbo Pajero (aka RedCar). 2" Lift, 33" BFG ATs, Rear locker,Custom 160a Alt, 9000lbs Warn Winch,Con-Ferr Custom built Conferr rack just for RedCar!, Safari Snorkel,3 AGM Deep cycles
1995 SR (Lucky)-SOLD..Kinda sad
Nissan Leaf(Astro), Tesla-S 85kw (Nicoli) & 2014 Rav4EV (Tesla inside)
Re: California smog test and my 93 Montero [Re: monte] #1003138 07/14/10 07:40 PM
Yeah, thats what I figured. Can you just weld in a generic CAT?
Re: California smog test and my 93 Montero [Re: strat10pro] #1003139 07/14/10 09:07 PM
8
89IsMine Offline
As long as it's a CA-compliant CAT, sure! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric W.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6019 MB (Peak: 0.6589 MB) Data Comp: Off Server Time: 2026-06-07 05:39:54 UTC
