Brake caliper issues #1003451 07/17/10 10:18 PM
j03 Offline OP
Hi all,
Im having issues replacing brake pads. Got the caliper swung up and changed out the pads but cant get the damn thing to go back down.
I have screwed the piston back in and there's plenty of clearance on the inside. Its the outside of the caliper im having issue with. There's about an 8th of an inch of there that is not clearing. Even putting the old pads on wont fit.
I've tried using a c-clamp to move the caliper outwards but it doesnt budge.
Also the caliper doesnt move very easily. I've got to use a screw driver and pry to swing it up and down.
What Im I missing here?
1990 4cyl isuzu trooper.
Thanks.
90 Trooper 2.6 - AMC head
Re: Brake caliper issues [Re: j03] #1003452 07/17/10 10:51 PM
j03 Offline OP
Never mind. I got it. I just had to keep pulling it towards me and swinging it at the same time to get it to move.
1 set of break pads - 3 hours <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Brake caliper issues [Re: j03] #1003453 07/18/10 05:04 AM
1
1986trooper2 Offline
I have had the same experience. Perserverence rewards.
Re: Brake caliper issues [Re: 1986trooper2] #1003454 07/18/10 06:53 AM
mlclark Offline
Isuzu Moderator
Did you get it off of the pin? If not, you should so you can clean it up. The caliper needs to float on the pin on one end and the slide/bolt on the other. If not, it will drag on one side of the rotor.
Good Luck,
Michael
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6016 MB (Peak: 0.6573 MB) Data Comp: Off Server Time: 2026-11-19 05:33:59 UTC
