A/C psi range for Gen III #1003716 07/20/10 04:49 PM
Inyo_man Offline OP
Is the psi range for the "low", suction tube 17-20?
My Gen III needs a recharge.
Is it a must to check the "high" psi? The charge kit only comes with a gauge for the suction tube.
'02 Montero: OME suspension, ARB front bumper, homemade skid plates & spare tire Blitz can mount, extended diff. breather, K&N air filter, Optima Yellow Top, BajaRack, IPF lights, Goodyear Duratrac 265/75/16's, RUD 4x4 Grip chains
Re: A/C psi range for Gen III [Re: Inyo_man] #1003717 07/20/10 05:36 PM
The gauges I am familiar with are grauated in temp degrees, and you charge it to close to freezing. You don't need to test high side pressures unless something is broken, and they are high enough to be dangerous and hard for a cheap gauge to deal with...
Re: A/C psi range for Gen III [Re: fasteddy] #1003718 07/20/10 06:45 PM
mxmikie Offline
low side should be 32-35
Re: A/C psi range for Gen III [Re: Inyo_man] #1003719 07/20/10 07:34 PM
P
pcc Offline
Pressure is dependent on ambient temperature. The re-charge can should have a temp/pressure chart to go by, but 35-40 low side (as stated) is good rule of thumb. I would also recommend using a thermometer on the upper air vent which will also help to know when to stop adding R134. Open front doors and use recirc so that engine heat won't give false ambient temp. Fan speed should be about half speed. But be patient and fill slowly a bit at a time and let the system settle before determining if you need more refirgerant.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6028 MB (Peak: 0.6581 MB) Data Comp: Off Server Time: 2026-06-10 07:23:25 UTC
