4lo in reverse #1003796 07/21/10 09:33 AM
8
87Raider Offline OP
Hello, my 87 w/manual trans wont stay in 4lo if i shift it in reverse, it pull the shifter out of gear, is this normal or is something wrong? Thanks Mike
Re: 4lo in reverse [Re: 87Raider] #1003797 07/21/10 02:49 PM
shadowgear Offline
Do you have autohubs? I wonder if this could be your problem? I'll let others more knowledgeable speak up.
'88 Raider 2.6L - SW Hubs, Weber 32/36, Off-road Pkg - Dead
'88 Monty 2.7L - 5" Lift, Weber 38, 33's, Dual Fans, Dual bouncy (more goodies to install) - Still Kicking.
'03 Monty Sport - XLS, BFG A/T's - Dead
Re: 4lo in reverse [Re: 87Raider] #1003798 07/21/10 03:09 PM
87Montero Offline
Which shifter? The Transmission or the transfer case?
Re: 4lo in reverse [Re: 87Montero] #1003799 07/21/10 04:31 PM
zarktheshark Offline
Sounds like tcase to me. either way, it is not normal. have you installed a body lift? I would check to see if there is anything getting in the tcase shifters way that is preventing it from fully locking in or is putting tenstion on it when in 4lo making it easier to slip out of gear. Since it is only happening in R, your running gear should be torqueing in the opposite direction, so maybe something is binding?
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: 4lo in reverse [Re: zarktheshark] #1003800 07/21/10 06:48 PM
mxmikie Offline
bad trans mount
Re: 4lo in reverse [Re: 87Raider] #1003801 07/21/10 11:55 PM
sandhill_raider Offline
It has been a while, but I had the same problem. There is a roll pin at the bottom of the tranny shifter that is pushed to far one way or the other. I used a pair of channel locks to even it up. I don't remember all the details. I'm sure someone here can help you out. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1988 Dodge Raider, Clearwater, 33x12.5 Buckshots, RB 2" Lift, Weber, 2.6L rebuilt by me with a lot of help from you guys. Thanks!
www.cardomain.com/ride/2980730
Re: 4lo in reverse [Re: mxmikie] #1003802 07/22/10 02:41 AM
8
87Raider Offline OP
It pulls the tranfer case shifter out of 4lo, also the trans mount is brand new. I'll open the top and check the roll pin, Thanks for all the help. Mike
Re: 4lo in reverse [Re: 87Raider] #1003803 07/22/10 03:05 PM
What about the body lift question? If you have lifted it, putting the tranny shifter in R might pull the tcase shifter back from the stretching of the boots. (?)
Re: 4lo in reverse [Re: MontyMcV] #1003804 07/22/10 09:22 PM
lordtrunks Offline
Correct the pin in the shifter rod that runs thru the transfer case is to far in or not enough
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: 4lo in reverse [Re: lordtrunks] #1003805 07/27/10 06:12 AM
8
87Raider Offline OP
Hello, the truck is not lifted, also I noticed that in will pull out of 4lo if I try to put it into 4th too,, Is the pin your talking about accessible from the top of the Transfer case? Also Is the pin on the transfer case shifter? Thank You For your Help..Mike
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6354 MB (Peak: 0.7587 MB) Data Comp: Off Server Time: 2026-10-21 22:05:16 UTC
