Gen 1 Mystery Wire #1004011 07/23/10 01:48 PM
RECON45 Offline OP
What does this go to?
Re: Gen 1 Mystery Wire [Re: RECON45] #1004012 07/23/10 03:10 PM
MarcDurant Offline
I just crawled under my truck and couldn't find any wires at all in that area. It's the driver's side, just in front of the rear axle, right?
89 Raider V6 manual
89 Montero 2-door Coupe "Super Legera"
91 Montero 4-door manual (Mint! Sunroof, cruise, power everything, BOUGHT FROM THE ORIGINAL OWNER!)
Re: Gen 1 Mystery Wire [Re: MarcDurant] #1004013 07/23/10 03:22 PM
RECON45 Offline OP
correct. i have not had time to trace it. as you can see in the pics it was dark when I even found it.
Re: Gen 1 Mystery Wire [Re: RECON45] #1004014 07/23/10 04:58 PM
RECON45 Offline OP
I was looking over the wiring diagram. Could it be for a rear blower fr a dual AC set up? Would they be prewired if they do not have it?
Re: Gen 1 Mystery Wire [Re: RECON45] #1004015 07/24/10 02:44 AM
TrailRaider Offline
The hub lock indicator on my 87 uses a similar looking plug. The t-case is sitting on a table at work. I'll be heading to work for a few hours in the morning and will snap some pics of it for comparison. Although that looks a little too far rearward for that. But it's worth a look-see.
'89 Raider V6 auto.
Re: Gen 1 Mystery Wire [Re: RECON45] #1004016 07/24/10 01:53 PM
RobCambo Offline
Gen 1 EV? <img src="/forums/images/graemlins/kewl.gif" alt="" />
I'll have a look-see in the morning...
1986 Pajero 2.6l 5spd manual SWB
http://s690.photobucket.com/albums/vv265/RobCambo/
Re: Gen 1 Mystery Wire [Re: RECON45] #1004017 07/24/10 08:43 PM
TrailRaider Offline
Took a look at the plug on the sensor I thought it was and it's 2 wires. The one in your picture looks to be 1 wire? So not likely for the lock indicator.
http://www.flickr.com/photos/trailraider/sets/72157624448203737/
'89 Raider V6 auto.
Re: Gen 1 Mystery Wire [Re: RECON45] #1004018 07/25/10 05:12 AM
RobCambo Offline
I have wires running inside a ribbed channel that looks the same as yours. The channel follows the brake / oil lines along the chassis rail under the driver's seat.
Following the wires through, I don't have a connector block, but do have some wire connections up the back of the 'box...
The wires disappear over the top of the 'box - near the inspection panel. No idea what they do up there though.
Hope that helps...
Re: Gen 1 Mystery Wire [Re: RobCambo] #1004019 07/26/10 04:37 PM
RECON45 Offline OP
Here is another picture I forgot to upload. I still have not clue what it goes to, but I will be under my truck this afternoon to look around some more.
Re: Gen 1 Mystery Wire [Re: RECON45] #1004020 07/27/10 01:48 PM
RECON45 Offline OP
I looked at it from the other side and the wire is curved around, so it is coming from my rear axle. there is 2 wires. I completely forgot my axle is an SR with an air locker. could this plug be sometihng related to that?
PHP: 7.4.33 Page Time: 0.005s Queries: 16 (0.004s) Memory: 0.6363 MB (Peak: 0.7612 MB) Data Comp: Off Server Time: 2026-05-25 19:01:56 UTC
