Looking for outside door window seals for 87 Gen1 #1004186 07/26/10 12:57 AM
87monty Offline OP
Im looking for some good used outside door window seals for my 87 Gen1. I still have the clips but the seal itself will not stay in place.
Thanks
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Looking for outside door window seals for 87 Gen1 [Re: 87monty] #1004187 07/26/10 03:37 AM
kewlynx Offline
I realize you want used seals, but I would also check the local body shops for availability as well.
**ubi apis- ibi salus**
Re: Looking for outside door window seals for 87 Gen1 [Re: kewlynx] #1004188 07/26/10 04:02 AM
87monty Offline OP
Not sure if they will, Its not the soft foam around the door but the hard rubber weather strip that snaps in place to seal out the water running down the window. if you look close you can see what trim im missing.
96 SR
Re: Looking for outside door window seals for 87 Gen1 [Re: 87monty] #1004189 07/26/10 05:26 AM
K_Raider Offline
Russell (aka rxinhed) should have one of those. Send him a pm. I just had rtv mine back on the other day.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: Looking for outside door window seals for 87 Gen1 [Re: K_Raider] #1004190 07/26/10 06:34 AM
The pieces that I have are not presentable, thus were not offered. Cameron (Cambo) has a parts car, LWB and SWB Gen I pieces are the same. Check around the Classifieds, others are actively parting car there.
Russell
Re: Looking for outside door window seals for 87 Gen1 [Re: rxinhed] #1004191 07/26/10 04:36 PM
87monty Offline OP
Ok will do thanks guys, I still have the piece but it flys off under high wind areas like when a big truck passes by.
Ill check with Cambo and see what he might have.
If it comes down to it ill use some Goop <img src="/forums/images/graemlins/smile.gif" alt="" />
Thanks.
96 SR
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6136 MB (Peak: 0.6833 MB) Data Comp: Off Server Time: 2026-10-24 07:18:11 UTC
