engine dies
#1004393
07/28/10 10:02 AM
engine dies when brake applied with a/c on
Re: engine dies
[Re: AkFordMan]
#1004394
07/28/10 04:07 PM
Isuzu Moderator
Don't use the brakes. Problem solved. <img src="/forums/images/graemlins/smile.gif" alt="" />
or
Let us know what we are working with here. Vehicle, engine year? What have you done so far to try and fix it?
Michael
Re: engine dies
[Re: AkFordMan]
#1004395
08/04/10 05:03 PM
Try checking for a Vacume leak in the brake booster,had this happen a couple of times.when you run your A/c you are putting a strain on the motor.If your booster is leaking when you apply the brakes it would be enuf to cause the motor to stall out.the booster is round black metal thing attached at the firewall beside the master cyl. when mine was leaking I would smell carbon dioxide inside the car while driving down the road.I beleive there is a diaphram inside this booster.also check the large vacume hose going to the booster
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5946 MB (Peak: 0.6477 MB) Data Comp: Off Server Time: 2026-06-20 19:11:11 UTCValid HTML 5 and Valid CSS
