Gen II Windshield Squirty thingy Question #1004411 07/28/10 05:36 PM
jdavis Offline OP
Finally got sick and tired of having a dirty windshield all the time and decided to look at the window squirters on the hood.
They have been sort of working for about year. The fix was easy, using a thin piece of wire I was able to unplug the holes.
Once working noticed there are four streams of water from the two washers. One set of streams seem to go about 3/4 up the window and the other set maybe a 1/4.
Would like to change where the water goes on the window. Are the squirters adjustable?
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: Gen II Windshield Squirty thingy Question [Re: jdavis] #1004412 07/28/10 08:02 PM
Michael_Morrison Offline
Stick four needles/pins back into the squirters and see where they point. Then see if you can correct the aim of the two pointing low by gently moving the needles so they point up higher?
Or, if they are individual type (tubes straight to single sprayers) all you need is pliers.
Sorry, I have a gen-3 & I don't have any idea what type I have!
http://www.icarumba.com/icarumba/resourc...le%20adjustment
2001 Montero XLS. Needs some TLC.
My B**ch ex-wife really treated this vehicle badly. Been fixing it up since I had to take possesion after the divorce.
Re: Gen II Windshield Squirty thingy Question [Re: Michael_Morrison] #1004413 07/28/10 08:41 PM
jdavis Offline OP
Thanks Michael,
It has the two prong squirter. I try the pin method this evening and see what happens.
Also, interesting reference site !!
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
ARB Front Bumper
XRC-9.5K Winch
Re: Gen II Windshield Squirty thingy Question [Re: jdavis] #1004414 07/28/10 08:51 PM
montypower Offline
You can buy the spray nozzles from the dealer. I believe they were under $20 IIRC. I've tried fixing them in the past without success.
** Cool to see someone from the NW. smile
1995 Montero SR - 2" Body Lift, 35" BFG KM2, 2.5" Suspension Lift, Manual Hubs Searching
Re: Gen II Windshield Squirty thingy Question [Re: jdavis] #1004415 07/28/10 09:11 PM
3
3esso Offline
they are totaly adjustable, just stick a needle into them(a bit thick one) and move as you like,
I clean them and re adjust almost evey rainy season, even the back window squirter can be adjusted
96 NJ SWB 3.5 pajero(Bone stock)
84 NA Hi-roof Pajero(also Stock)
Re: Gen II Windshield Squirty thingy Question [Re: montypower] #1004416 07/28/10 09:27 PM
jdavis Offline OP
I was able to clear 3 of the squirter holes with a thin piece of wire from a wire brush and a lot of patience. One still needs a bit of work but it is better.
There are few us up in the great NW. There are quite a few people on the board from the Portland area.
Will be running the <a href="www.nwjeepn.com/naches.htm" target="_blank">Naches Trail</a> either next month or the month after. We'll probably camp two nights and run the trail on Saturday. If you can make it up that would be cool.
they are totaly adjustable, just stick a needle into them(a bit thick one) and move as you like.
Thanks for the confirmation 3esso, I was a little worried about sticking a needle in them a breaking something.
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
ARB Front Bumper
XRC-9.5K Winch
Re: Gen II Windshield Squirty thingy Question [Re: jdavis] #1004417 07/28/10 10:00 PM
ryany Offline
To get them really clean, remove the squirters completely and soak them in vinegar for a few hours to remove the hard water deposits. Then reinstall and aim the nozzles where you'd like them to squirt.
I only use distilled water in my washer reservoirs and don't have any more problems with them becoming clogged, but then again I don't have a need for any freeze protection in my washer fluid.
95 Montero SR
Re: Gen II Windshield Squirty thingy Question [Re: ryany] #1004418 07/29/10 12:18 AM
clr should also work if the vinegar isn't strong enough.
With the gen II's I havent had any issues with clogging. With the gen I's I cleared the holes first poking out the blockage using a small wire strand and then literally blowing out the item. When doing this, I discovered there were 2 blockages and not just what was blocked at the tip of the water nozzle.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6259 MB (Peak: 0.7267 MB) Data Comp: Off Server Time: 2026-06-09 23:17:38 UTC
