cobra 29ltd classic #1004527 07/29/10 09:47 AM
sarahjames124 Offline OP
Can someone out there help me out?? Im trying to make my radio a bit more powerful and I was wondering what I would need to do?? Basically I have a Cobra 29LTD Classic straight out of the box running with just the basic power and 5 ft Firestik antenna with no mods currently done to it please let me know what I can do to get more range and more power to my radio... thanks I am a full on Novice with this but I am looking forward to learning.
Re: cobra 29ltd classic [Re: sarahjames124] #1004528 07/29/10 03:25 PM
4x4Wire Offline
Out of the box, CB radios are power limited by law. As such, many people are shifting to amateur radio for communications. Note, a license is required to use the amateur radio bands.
The "best" option for improving communications with CB is using a full-wave antenna (102" if I recall correctly).
Or, use a 5/8 wave antenna. Your 5 ft Firestik is a 5/8 wave antenna.
And, you need a good ground plane. The antenna mount should be bolted direct to sheet metal with as much of the antenna above the vehicle body as possible.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: cobra 29ltd classic [Re: sarahjames124] #1004529 07/29/10 06:15 PM
Oyaji_Jon Offline
Your location says Ireland, so your rules may be different, but here is a link to the FCC webpage that highlights the law for CB use in the US. There is also a link to the actual verbage of the law on that page.
http://wireless.fcc.gov/services/index.htm?job=operations&id=cb
As John said, your only legal way to make your radio function more efficiently is to work on your antenna and connectors. Find an SWR meter and tune your antenna and conductor while ensuring the maximum ground and antenna exposure.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: cobra 29ltd classic [Re: Oyaji_Jon] #1004530 08/01/10 03:40 PM
52degrees Offline
Or buy a linear amplifier <img src="/forums/images/graemlins/nana.gif" alt="" />
KG6VNX
Re: cobra 29ltd classic [Re: 52degrees] #1004531 08/01/10 06:02 PM
4x4Wire Offline
I was on a run several years ago. One of the participants had a linear he was touting as the answer to CB communications. He could talk to someone over 400 miles away. But, he couldn't talk to someone 100 yards away.
And, by the time everyone adjusted squelch to compensate for the close proximity to the high power, we had better verbal communication than radio communications between vehicles.
John Stewart
Editor - 4x4Voice
Moderated by  4x4Wire, Oyaji_Jon
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6078 MB (Peak: 0.6730 MB) Data Comp: Off Server Time: 2026-06-07 04:24:49 UTC
