bilstein 5150 #1004857 07/31/10 10:40 PM
BT100 Offline OP
Hi all
BT100 here, I've posted here infrequently over the years, been lurking mostly! Got a '96 T100 SR5 4x4 extracab w/104k miles. Lifted it with a 4" SL and running 32" BFG all terrains ( I know, gotta get some 33's). Anyway, have any of you used bilstein 5150 shocks on a lifted T? I'm having trouble finding part numbers for these so If ya got #'s that would be great! Also anybody know of a U-bolt flip kit for these trucks, looking to get the shock mounting plate up out of harms way! Any info or comments are helpful...
Thanks
BT100
Re: bilstein 5150 [Re: BT100] #1004858 08/03/10 08:03 PM
Kookadala Offline
I have them on my truck. I have 35" tires with a 4" lift so the length would be different. You also need an adapter to convert the top post style shock to a hrizontal bolt style, since the 5150s dont come in a post top. That will also affect the length you need. See JK Adapters for the conversion piece.
Good luck
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: bilstein 5150 [Re: Kookadala] #1004859 08/04/10 12:46 AM
BT100 Offline OP
Thanks Kookadala!
I also have a 4" susp. lift so the shocks I need should be the same as yours. I don't have a body lift but that shouldn't affect shock length. Would you happen to have part numbers?? Do you feel they (the 5150's) are a worthy upgrade from the 5100's?? I will track down the adapter needed to convert "eye to post" mount for the front, Thanks again..
BT100
Re: bilstein 5150 [Re: BT100] #1004860 08/05/10 08:51 PM
Kookadala Offline
I found this from an old post of mine, which also reminded me that the 5150s I have are too soft for my heavy front bumper. Keep this in mind if you have an aftermarket bumper/winch, you want a different valving for your shocks. Good luck, Jed
Part Number Travel Description Valving Reservoir Ext Length Col Length Shaft Dia Mounting
BF5-A194-H1 6.48 5150 Crossflow 255/70 Attached 18.78 12.30 14mm eye/eye
Re: bilstein 5150 [Re: Kookadala] #1004861 08/05/10 09:56 PM
BT100 Offline OP
Kookadala
That is exactly what I needed! Thank you again for the info!!
BT100
Re: bilstein 5150 [Re: BT100] #1004862 08/06/10 01:05 AM
adam Offline
BT, check Trail Gear out, too. I got my ubolt flip and shock mounts from them. There was some bad blood/customer loyalty stuff between Trail Gear and Marlin for a while iirc, but I think it's passed for the most part, and fact of the matter is TG is quality product.
~Adam
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6091 MB (Peak: 0.6788 MB) Data Comp: Off Server Time: 2026-05-29 22:20:27 UTC
