3.5L DOHC - Blue Smoke on acceleration :( #1004891 08/01/10 02:00 AM
montypower Offline OP
I have a 1995 Montero SR 3.5L DOHC 139k miles. It has blue smoke when accelerating from idle. It's a puff of smoke then goes away.
On my 1992 Montero 3.0L the culprit was the valve stem seals. I replaced them and no more smoke. I also replaced them on a 1990 Montero and it fixed the blue smoke problem.
I'm not excited about replacing 24 valve stems. That's going to be a tedious project. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Are the valve stem seals the likely issue? Or is there something else I should check for?
<img src="/forums/images/graemlins/patriot.gif" alt="" />
1995 Montero SR - 2" Body Lift, 35" BFG KM2, 2.5" Suspension Lift, Manual Hubs Searching
Re: 3.5L DOHC - Blue Smoke on acceleration :( [Re: montypower] #1004892 08/01/10 03:29 AM
mxmikie Offline
yep valve stem seals mitsubishi valve stem seals are junk
Re: 3.5L DOHC - Blue Smoke on acceleration :( [Re: mxmikie] #1004893 08/01/10 05:07 AM
hazy_daze Offline
+1 Valve Stem Seals
Re: 3.5L DOHC - Blue Smoke on acceleration :( [Re: hazy_daze] #1004894 08/01/10 05:37 PM
Does anyone have experience replacing the valve stem seals on the 3.5L?
Re: 3.5L DOHC - Blue Smoke on acceleration :( [Re: montypower] #1004895 08/01/10 07:41 PM
ryany Offline
IIRC, somebody on this forum was able to do the 3.5 DOHC valve stem seals without removing the heads, but when I did mine several years ago I tried 3 different valve spring compressors with no luck (really limited space around the valve springs on these heads) before I finally ended up pulling the heads off to replace them. I did everything on my motor at the same time - timing belt, valve stem seals, lower intake manifold, plugs, wires, belts, hoses, radiator rodded, even had a valve job done since the heads were off and getting disassembled anyway.
95 Montero SR
Re: 3.5L DOHC - Blue Smoke on acceleration :( [Re: ryany] #1004896 08/01/10 08:28 PM
mxmikie Offline
i did mine i bought the tool to do them i had to make a fitting for the springs since they are so small now i rent the tool to do it you have to remove the cams
Re: 3.5L DOHC - Blue Smoke on acceleration :( [Re: ryany] #1004897 08/01/10 10:39 PM
That's a major job. Do you remember the head rebuild cost? Did you do it yourself?
Re: 3.5L DOHC - Blue Smoke on acceleration :( [Re: mxmikie] #1004898 08/01/10 10:41 PM
Do you have any information on the tool you rented? Did you use the air compressor trick to hold the valves up? Would you go this route vs pulling the heads?
Re: 3.5L DOHC - Blue Smoke on acceleration :( [Re: montypower] #1004899 08/02/10 06:27 AM
mxmikie Offline
i did not rent the tool i bought the tool then i had to make an adapter for the mitsubishi springs cause they are so small and now i rent the tool out it comes with the fittings for the compressed air hose it has all you need except for the cuss words to remove and replace the valve springs without removing the heads
Re: 3.5L DOHC - Blue Smoke on acceleration :( [Re: mxmikie] #1004900 08/02/10 06:40 AM
MX, you're cool <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6412 MB (Peak: 0.7660 MB) Data Comp: Off Server Time: 2026-06-07 10:31:46 UTC
