Anyone using a performance chip? #1005370 08/07/10 04:39 PM
Inyo_man Offline OP
Has anyone tried using a performance chip in their Monty?
I think I've talked to a few folks who have "tuners" in their rigs, but I was wondering if people have found a "chip" that actually improves performance.
I'm very happy with my low end torque, however, some manufactures claim their chips helps with MPG and top end.
Has anyone tried one of these "plug and play chips"?
'02 Montero: OME suspension, ARB front bumper, homemade skid plates & spare tire Blitz can mount, extended diff. breather, K&N air filter, Optima Yellow Top, BajaRack, IPF lights, Goodyear Duratrac 265/75/16's, RUD 4x4 Grip chains
Re: Anyone using a performance chip? [Re: Inyo_man] #1005371 08/07/10 05:23 PM
There are no chips for the V6 computer. You can use a piggyback tuner though. There is one company working with a prom replacement but this is not an ECU that can be socketed like some of the 4 cylinders.
Re: Anyone using a performance chip? [Re: OldColt] #1005372 08/07/10 10:16 PM
Inyo_man Offline OP
Thanks for the info.
There are a few companies out there that are selling chips for Gen III rigs, I was wondering if anyone has actually tried them and what their results have been.
Re: Anyone using a performance chip? [Re: Inyo_man] #1005373 08/09/10 06:11 PM
dougl3nc Offline
There are no "chips" for our Gen3 rigs, just some piggy-back tuners if you can find them. Some gents in Australia are starting to "flash" the ECU with a new program, but I think we are pretty much screwed here in the US.
There's just not enough following here and the Pajero/Montero hasn't been sold here officially in 5 years...not like there was any aftermarket then either.
1989 Raider SWB Auto 3.0L...It's ALIVE!
Currently on a shakedown cruise...
Re: Anyone using a performance chip? [Re: dougl3nc] #1005374 10/28/10 02:38 PM
DonMitsu Offline
Has anyone had good luck with a piggy back tuner on a Gen 3?
2004 Montero
Re: Anyone using a performance chip? [Re: DonMitsu] #1005375 10/28/10 03:57 PM
You can reprogram the 98 and newer ECU. There is no need for piggybacks or chips.
Re: Anyone using a performance chip? [Re: OldColt] #1005376 10/28/10 09:43 PM
DonMitsu Offline
What's the best way to reprogram it to squeeze out a little more power?
2004 Montero
Re: Anyone using a performance chip? [Re: DonMitsu] #1005377 10/28/10 10:36 PM
Each engine must be tuned first on the dyno for max power pulls, then interpolated on the road with a wide band oxygen sensor. It can be done with an integrating accelerometer like a gtech pro, but this requires repeated runs on probably public roads. level one mile ones is nice...
In short, there's no way to give you a short answer. Sorry. Tuning equals time and instruments and some way to change the eprom chip memory to modify the fuel maps and fuel trims.
A good short, sort of, tutorial on all you ever wanted to know about tuning efi is on sdsefi.com in the tech section - see menu at bottom of home page. good stuff.
Re: Anyone using a performance chip? [Re: OldColt] #1005378 10/29/10 03:05 AM
3
300D50 Offline
I'm working on reverse engineering the rom from a 1990 Mighty Max V6 ecu, not sure if the motero ecu's are eprom or not like this one was.
So far it shares quite a bit with a DSM rom, fuel tables, etc all seem to be present, there's a redline someplace in there, etc.
I don't have a running V6 so I can't test anything out, but it seems easily tuneable.
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" />
1988 Power Ram 50 2.6 Long Bed
1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
Re: Anyone using a performance chip? [Re: Inyo_man] #1005379 10/29/10 08:34 AM
Before going into moding your ECU you should look into 4.90?s if you already have them think about getting some 3.15?s from Marks4wd. Lots more power there.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6414 MB (Peak: 0.7646 MB) Data Comp: Off Server Time: 2026-06-22 07:35:42 UTC
